My 2021 Chevy trail boss Bluetooth is undiscoverable, it worked fine one day then the next day it wouldn’t connect. I unpaired for hit forget device. Now the truck don’t even show up on mobile devices. I have connected via USB cord and the information systems just keeps saying retry. I have tried connect multiple different devices to no avail. When I go into phones and try and touch add phone it is grayed out. What can I do to fix this.
I semi have the same issue. Sometimes CarPlay will connect, other times not. When it doesn’t most of the time Bluetooth will not either. I haven’t had any luck with the dealer, but there are a couple of service bulletins for software upgrades related to Bluetooth and CarPlay. Maybe that might help.
I have consulted the owners manual and tech support who did multiple force restarts on my truck. They are suggesting take it to the dealership which where I live and my job it tough as they close at 5 pm and are not open on the weekends. I was just looking for other possibilities for a fix or what the issue is.
Unfortunately, it sounds like you'll need to take it to the dealer.  I have yet to find a dealer that doesn't do after hours drop off.  I use this service often.  The real question is, how big of a back log do they have?  My wife's Traverse had a leaky trans line.  Dealership said they were backed up 3 weeks on trans repairs.  And, because they were first come first serve they wouldn't hold a spot in line if she put her name on a list.  They wanted the car to sit there for the entire 3 weeks.  I took it to an Aamco and was out the door a few days later and only $200 poorer.  The leak turned out to be a damaged o-ring.  Hopefully your dealer isn't like mine with the long waits.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
