I have an 07 Cadillac Escalade Esv and it's got a texas speed cam, stainless long tubes, tuned on 93.. long story short my factory awd BW4485 (NR3 RPO) is about to go out and I would like to swap in either an MP1222 or a NP261HD.   The MP1222 comes in 08-13 silverado 1500s with 6l80es, it is a manual floor shift unit which would be easy to make a linkage for.  The MP1222 or RPO code NQG that I'll need if I'm correct is a 32 spline unit that would have came behind RPO code MYC or 6l80e transmission.  I'm looking for any knowledge, if it can be done and what all I'll need to change.  Thanks in advance
Whatever you do you'll have to have all the programming the same as the donor type vehicle.  Do you want a 2-speed transfer case?  The 2010s came with the electronic single speed MP3010 and the 2-speed case is the MP3023.  The latter was paired with the 6.2 engines in the 2010-2013 GMC Sierras, the 2009 LTZ Tahoe and the 2010 GMC Yukon XL SLT.
I went to a local junkyard and pulled an np261hd from an 02 silverado 3500 dually.  It was a 32 spline unit off of a 4l80e.  I brought it home earlier today and pulled my cadillac drive shafts and they fit into the np261hd, I pulled my transfer case out and there were no sensors anywhere on the unit.  Its a locked awd t case and since the np261hd is a manual shift t case I went ahead and put my 6l80e extension housing on it and installed it into my cadillac.  It is no longer awd and is now a manual shift 07 escalade esv, it had 2wd, 4low, and 4 hi.  All I need is to mount the shifter and hook up the linkage.  I put it in 2wd and drove it 40 miles and it worked out flawlessly, the factory driveshafts even fit.
Now that is awesome Gabe!  Shouldn't be too hard to find the linkages out of a pickup and am sure you have a work around for installing them in and around the console.  Photos would be great and the Denali guys would love to learn of this swap on this forum and over at the TahoeYukon forum.  Very cool.  Can you post up some photos when done?
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
