Ok So i have a 2021 sierra elevation crew cab. I am wanting to change the wheel set up. I love the look of 12" wide rims but don't want rubbing. So I was considering a 10" wide rim. What leveling kit do you guys recommend to preserve the factory ride?
There are a billion posts about this already and 5 minutes of searching would go a long way.
However, the bottom line for "just a level" is as follows:
If you want to do a spacer level, then brand is irrelevant and they all do the same thing.
If you want to do a suspension level, Bilstein and Eibach are quality setups that most people go with.
Edited by Gangly
I have the same truck, and installed the factory leveling kit.  I gained two inches up front and it looks great.  I have the factory wheel set up, but put on 33x12.5 BFG MT KO3 Tires.  No rub, great look, factory ride... hope that helps
Edited by Adam Shell
added pics
I installed Motofab 2.5" upper leveling kit my self and also added a 1" block in the back.  If you do consider doing your self be very careful with cv axles to not stretch and rip boots also get an alignment done after.
Probably not what you want to hear, but I wouldn't install one.  They look good, but they all compromise the ride, they make it hard to get perfectly aligned, and I've experienced issues with the truck eating ball joints since the install.
Granted, that was all on my 2015 Silverado, not my 2020 Sierra, but still...
Where did you get the 1 in block from?
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
