I would only get camper springs or the plow package if you really need it. While the ride is still acceptable with the heavier front springs, it is best with the standard springs if you drive lightly or moderately loaded. I have the camper springs on a 3500hd cclb srw gas, but now that I’ve driven it a while with my 2000 lb slide-in camper, if I was doing it again, even with a bit heavier camper, I’d go with the standard springs. 3000 lbs camper weight is about the point where I’d go with the camper springs.  Note that, with my 2000 lb load, the rear suspension has about 2 inches of travel left before the 3500hd rear overload springs engage, so my impressions of the ride would apply to a 2500.
JR, it's good that you are enjoying your new truck and getting in some camping!  Question about your statement on the overload springs.  Do I understand correctly that even with your one ton camper in the bed the frame mounted pads are still not touching the top overload leafs that come on the 3500s?  Wow!  I would have thought you would have at least been putting at least a little pressure on the overloads.  The strength of the main leaf springs is no joke!
Yes you understood correctly.  I looked at the frame pad clearance again just now. The suspension has about 1.5 inches more travel (capacity for more weight) before the overload springs contact the frame pads. It’s actually a little annoying because whenever I go over a large dip or bump and the suspension moves that much I hear a slight clunk when the springs make contact.
My sticker payload is 4054 lbs, and the fender heights front and rear are equal with the camper on. Unloaded the rear is about 1.5 inches higher.
The camper is pretty light compared to most because it’s a pop up. Factory says the weight with options and the tanks full is 1800, and I figure I have nearly 200 lbs of stuff in it.
Edited by Another JR
Nice looking rig!  I guess if your payload is 4054 then it makes sense that half of that wouldn't have you touching the overloads.  Would something like this help?  https://www.etrailer.com/Vehicle-Suspension/TorkLift/TLA7202.html.  If you watch the video that shows the 2017 Chevy 3500 long bed it shows how they are installed and how they work.
Replying to my own post.  Who does that?!  JR, you might want to consider these as well.  I found these when looking through the comments of the Torklift pads.  They might solve your issue without messing with the overload system at all.  One benefit of these I can see is you won't be on your overloads as much which might help with the ride.  https://www.etrailer.com/p-TGMRTT35D.html#exp-productdetails=.reviews
On 9/29/2021 at 7:28 AM, Kjduvall said:
I have the x-factor synthetic leather and the fit is amazing. my truck is a reg cab so i only have front pics. I dont think you could go wrong with the neoprene covers either, vertex makes a high quality product.
Were the original seats leather?
The ride of the rear suspension is fine, particularly with the camper installed - I just don’t like the little clunk I hear when going over big bumps when the camper is on and it hits the overload springs. The front suspension (I have the camper springs, so one step up from standard) feels a little stiffer than the rear as I drive over anything that causes significant suspension travel, which feels a little “off” relative  to an ideally balanced suspension. I like the increased lateral stiffness to reduce roll, but it would be a better balanced suspension with the standard front springs. As I said, I think if I had 3000 lb in the back and was on the overload springs it would be balanced.
These are relatively subtle feel issues that many people probably wouldn’t notice. The truck really does drive very nicely, and the increased roll resistance is nice if I inadvertently enter a curve too fast. It drives sort if like a giant 9500 lb sports car on windy paved roads.
Understand.  Just thought those might be options that would prevent the pad to overload clunk.
Thanks. Both of those products would cause my overload springs to be engaged earlier, causing the truck with the camper to be on the overload springs when at rest. That would make the clunking occur less often, but would make the highway ride more stiff. I’d prefer not to do that. Maybe something like the stableloads but smaller to keep the gap and softer to make the contact silent.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 1,090 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
