Any suggestions for cleaning the "leather-like" material used on the dash and door panels in the Serra Denali? I have tried Meguiar's Quick Interior Detailer Wipes and Chemical Guys Total Interior, but was hoping to come across something that does the job better.
Any suggestion are appreciated!
Pretty sure you are referencing the Vinyl. Currently I am using a turtle wax interior spray bottle cleaner that does the job fairly well. I'll get the exact information when I get off work
I have always used the same products that I use on the rest of the interior the soft touch plastics are still plastic. Any leather surfaces maybe seats and steering wheel use a leather product. But I may be wrong but all the other surfaces are plastic but there just soft touch plastic.
Also use 303 on every surface but the seats.  It Works great
I use an actual leather conditioner on the seats due to not wanting any residue to form in the perforated seats.    I thought I read that is a concern with 303 on the seats
I always thought the dash and doors were carbon fiber imitation of leather have been using Armorall or McGuires Leather conditioner.
Couldn't find the bottle of my turtle wax interior stuff online anywhere so it must be discontinued or something.
Plain water and a micro fiber towel.  I've found many cleaning products seem to leave everything streaky and looking worse than I started.
Adams Polishes Interior Detailer and then Leather Conditioner for the seats. Swear by both in my wife’s Acadia Denali and the interior detailer in my RST.
