21 hours ago, Mac-427 said:
I got my GM assist handle today.  The part number is 84726114 and it is described as an "F-HANDLE." I checked fit and the holes in my truck bed line up, but two of them are unthreaded.  I'm going to hit the hardware store tomorrow but would appreciate knowing what to use on the unthreaded holes to secure the handle.
I ended up using 8mm Nut Serts on the two unthreaded holes to match the 8mm threaded hole and they worked fine.  It's strange because the all the GM parts websites said the lever didn't fit my 2020 Silverado 1500 Custom while it did fit the GMC 1500.  My guess is that the Silverado has two unthreaded holes while the GMC has all three threaded.  Bottom line: The lever will fit Silverado trucks but you have to use Nut Serts on two of the mounting holes.  Accordingly, I bought a kit from Amazon that worked well and will be a great help in future projects.
https://www.amazon.com/gp/product/B081GDRTXP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Looks great.  Wish I could have used this solution on my LT.  FYI, I received the HitchMate Grab Handle and it works fine.  While it's advertised to work on either side of the tailgate, which I'm sure is true for some trucks, it can really only be used on the right side of my truck.  The bottom anchor point fits precisely over the fixed metal housing that the tailgate's hinge fits in, and does not place pressure on the tailgate that was a concern of an earlier poster.  If adjusted for use on the left side, the fit would be less than ideal, and would put pressure on the tailgate's pin that fits into the left side pin bracket, which is something I wouldn't want to do.  It's solidly made, and will make a great self-defense weapon against any antagonist (grizzly, bull moose, etc.).
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
