Hey everyone! I'm new here and looking for some help on my truck. I'm stumped so far.
2013 Sierra 1500 5.3
There is a "tremor" when I turn the wheel that I feel mostly in the floorboard. The only way I know how to describe is it "feels like a helicopter sounds". It's still there when I drive straight, but noticeably less.
Tie rods, hubs, CV joints, and everything in the front end seems tight (at least as far as I can tell). New tires. Balanced tires.
Does anyone have any ideas or suggestions on what to check for?
Thanks in advance!
Thanks in advance!
So it's kinda rhythmic would you say while turning?  How many miles?
Max play for upper and lower ball joints is .5 mm.  Max play for inner and outer tie rods is 1 mm.  Check bushings for upper and lower control arms, check bushing for sway bar end links and frame mounts too.
Front differential is supported by two brackets with 2 bushings in each, the rack and pinion has 2 bushings also that secure it to the frame.
Have someone visually look at the tires when you are turning or backing to see if the caster settings are normal.
Someone recently complained of a similar issue and it turned out one of his struts was broken and didn't realize it until he was taking it apart.  Almost took his head off too.
Yes it's rhythmic. It seems to follow to rotation of the wheels (slower rhythm when slow turning, faster when faster). 104,000 miles.
Ok thank you for the lead. I'll have to check on all that.
Ok, well, now that coffee has woken my brain, the rhythmic movement won't be the suspension, it will be tires, brakes, axles, u-joints, etc.
At 104K miles, that's typically how long the front hubs last.  My front ring and pinion has been howling for a while but there's no vibration.
So, check the hubs for play/noise, check the rotors and pads, make sure everything is tight and the slides are still working, calipers still floating, etc.
It doesn't sound or feel like hubs. It feels like something is warped or out of balance.
4WD is off, and it's not skipping when I turn. Brakes and U-joints might be good places to look though.
Did you inspect the front end with no load on it? Set the truck on jack stands located on the frame allowing the wheels and tires to hang free. get a good flashlight and inspect EVERYTHING you can see, use a mirror. Replace anything cracked, burned, or wobbly.
When I got my Avalanche (06) I replaced everything but the pitman arm, I couldn't get a wrench on it and it was tight anyway.
I don't know if your truck uses the same idler arm as mine dose but it's a POS IMHO. Chevys traditionally put a lot of stress on the idler arm, In my 16 years working on the USAF vehicle fleet Chevy idler arms were constantly replaced. Maybe they fixed this and maybe not.
reach under with it on the ground and see if you can spin the front driveshaft. it should turn easily if the transfer case is in 2wd and the hubs are disengaged. the dildo that engages the hubs are known to get stuck due to corrosion around the threads. idler arm etc will NOT make that noise
its also possible that the dog that engages the axles is stuck causing 1 side to be engaged so make sure it spins easily and you aren't spinning the spider gears
Alright, I got it figured out.
It was the left front hub.
The tremor gradually turned into a small "wobble" that I felt in the floorboard all the time but especially when turning right. I took the wheel, brakes, and rotors off and then spun the hub by hand. Only after removing all these things and listening closely could I hear a faint "clicking" sound when turning it. After I removed the hub, I spun it again (off the mount), and it felt rough. This caused me to rule out the CV joint and determine it was indeed the hub. The whole process took about an hour or so in my garage.
I installed a new hub and that seems to have solved the problem. Thanks again for all your help!
Forgot to add, there was NO play in the wheel. Usually when bearings in the hub are shot you can jack the vehicle up so the suspension is free, grab the wheel, and rock it up/down and back/forth and you'll feel a little play in the wheel. There was none of that that I experienced.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
