Started getting service 4wd message. Dealer was able to squeeze me in quickly, but were unable to clear a code/do a relearn and didn’t have time to go any further. Mechanic mentioned a communication issue.
when I put the truck in neutral and attempt to put the truck in anything other then 2wd I can hear a click then I get a service stabilitrac message.
any insight or anything I can try before it goes back to the dealer. I am quite mechanically inclined.
Anyone ? I’m going to check some grounds tomorrow. Confused as why I’m hearing a click when I take it out of 2hi to go into 4wd and then service stabilitrak comes up. But Then goes away when switched back to 2hi
Maybe something to do with this TSB:
MC-10113854-9999.pdf
  • 3 weeks later...
DTC C0321 04: Transfer Case Lock Circuit Open
local garage was able to pull this code up but they weren’t able to clear it.
Anyone? It will be going to the dealer after Christmas. I’d just like to see if I can check anything
I would start with checking the electrical connections on the encoder motor. Also make sure the encoder motor is not loose. Might want to check the grounds in that area as well. Maybe reset everything by disconnecting the battery for a while. Maybe double check the owners manual instructions, just in case something is getting overlooked while trying to change the transfer case settings. You could also put all 4 corners of the truck off thew ground, and try it that way, so that the wheels and drive system can move as needed when the gears line up. Uh... Maybe check the t-case fluid? Maybe check for burnt out fuses. Having the engine in neutral, with the RPM's up a bit and the headlights off, might send a little more power to the encoder motor.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
