On a 2019 Silverado 1500 crewcab,  it has a 60/40 split seat in the back. Is there a way to just remove the bottom seat cushion on the 40 side? With out taking the whole seat out. Spilled milk and need to replace cushion.
Edited by George Arellano
Misspell
Try finding an upholstery video on YouTube. You should be able to pull the seat cover off and access the cushion without removing the bench.
Welcome to the site.
This may help.
Technical Bulletin - 2019 Chevy Silverado Rear Seat Removal (2).pdf
  • 7 months later...
Fold bottom cushion to up position,  look at bottom of seat, you'll find a black plastic strip that runs along the bottom.  It's a hook type fastener.  Pull it down and towards the front of your truck. It's easier to start from one side. After that look for zippers and undo all. Then there's velcro straps attaching the seat cover to the seat belts. Undo those and then you should be able to slide seat cushion and cover off of frame.  Taking the cover off of the cushion is another thing. There's plastic hook type strips like the first black one you took off the bottom of the seat cover at the beginning.  They run along all the seams of the top of the cushion. You'll see what I'm talking about when you get to that point.  There actually easy to do once you figure them out and they are pretty durable. Then you can clean cushion and cover separately.  Hope this helps. I watched several different YouTube videos and got a little bit of info from all that made it easier to figure it out.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   3 Members, 0 Anonymous, 959 Guests (See full list)
