Cylinder 1 is shot. I believe it was a spun bearing. Oil was changed on schedule and never showed any warning signs.
New engine estimate is $9k. Seeking any help guidance I can get because dropping $9k is not an option.
Posted on another forum but basically used engine and pay a private mechanic to do the work. It is still going to be costly but it won't be $9k
If it is just a spun bearing, then you don't need another engine, at the most, new or reground crank, maybe a connecting rod, and parts, much cheaper than $9K. sounds like they are not being honest with you!
Find a mechanic that will do used engines then. Other than that you are looking at a new truck.
@rlcole321not every time. Sometimes you can save it but often times a spun bearing is the death of a block. Don't really know the extent of OPs damage
You may be able to find a used engine and a shop/individual to do the work. But is it worth it? Would you rather have a brand new engine (with a warranty) or a used engine that may already have something wrong with it?
Or if spending money really isn't a option.. I'd inquire at a dealership and see if they'd take it as a trade in. They may just do it because they'll come out ahead in the long run.
Edited by M1ck3y
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,638 Guests (See full list)
