New to page thanks for any advise. 97 Sierra 4wd. Transfercase motor just clicks (even with ignition off) lights flash then stay on 4wd low. Never engages. Has new tccm, encoder/motor, switch on dash, front diff acuator, all fluids a full. Any ideas?
Edited by Debeard77
   Hi.
Can you provide more specific information?
How did this problem come about?
Can you shift between different ranges at all?
What do you mean that it clicks even when ignition is off? What makes it click? Pressing buttons?
Did this problem happen before you replaced all that stuff, or did it happen after you replaced all the parts?
Just got the truck not long ago was doing before parts. With the key out the transfer case motor will  keep "clicking" like its trying to shift the case..there is no 4wd at all with not go in low or high. Have to take the fuse out or will just go and go.  Could the case be broke stuck in 2wd?
Edited by Debeard77
Also, when you shift the transfer case, are you following the instructions in the owners manual?
Simply pressing the tranfer case shift buttons is not the correct procedure. There are other necessary steps that must be taken if you want to change the tranfer case settings.
try disconnecting the battery. sometimes that works to reset the system. the only time I have seen that happen was on a 2000 Blazer with a bad battery. new battery and the system reset
9 minutes ago, Debeard77 said:
Just changed it no flakes. What steps are u speaking of?
I cant tell you what your vehicle needs. Here is what my rig wants, in order to shift from 4L to 2H:
1)  Engine running.
2) Transmission in neutral.
3) Vehicle rolling forward or backwards at 1 or 2 MPH.
4) Press transfer case shift button.
Your rig might want a different procedure.
if that doesn't work remove the motor from the tc and see if you can shift it manually. if you can't you found the problem
Ya, that's a good idea. At least he could get it into 2H so that it can be driven.
It may shift by hand more easily of the transmission is in neutral. (might want to chalk the tires).
I don't know if its possible to install the motor incorrectly but thats a possibility as well
Pulled the encoder motor of transfercase I can shift it manually. Does anyone know how hard it should be to shift? Seemed like it took a lot of force to shift it.
it may be normal with out the truck rolling. with the encoder motor off but connected does it work when you try different modes? does it still click when shut off? if it seems to be working properly manually put it in 2hi and reinstall the motor and see if it works
the manual shift tcs sometimes take a good tug to change modes so as long as it does shift its probably ok.
    • Spot on. The government makes ridiculous mandates, and this causes manufacturers to jump through hoops for every TENTH of a MPG. Main reason quality is in the toilet and prices are in the stratosphere.   The gov't tightened the MPG requirements so much 5 years ago that the only way manufacturers could meet these absolutely ridiculous numbers was to go all EV. Hence the push.     Nobody hates good MPG, Atlas - nobody is "whining". Your side has that trait all locked up. What a stupid argument attempt!   What I particularly hate is the government meddling in the free market system. Had this system been allowed to work as designed and intended by our Founders, cars and trucks would be hitting numbers that would blow our minds, all while costing 30% LESS. Not only that, but engines could probably hit 150k miles again without needing major internal surgery.   My forty year old Ford 302 has 312k on it. Wonder what changed?🤔
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
