I put it in 2wd and put encoder back on. Lights just flash on dash and then 4 low light stays on even though it's not in 4low. Obviously will not shift does nothing. And yes encoder still clicking even with truck off.
did you try the modes with the encoder removed from the tc? it may be out of phase or just a defective part
That's what I was thinking also. I have also heard you are not supposed to run the encoder when it's not installed on the tc. I didn't put this one on so I am thinking I will try a different one.
I've heard that too but its possible some1 did and its out of phase now and where it doesn't work anyway its worth checking
did you have a chance to check it for tc codes? its a pretty simple system but it may shed some light on the problem
It is not showing any tc codes. I am going to try a new encoder. Thank you for you help
Tried the new encoder. No luck.. same thing clicking like crazy and doesn't shift just shows 4 low when it's really in 2wd.. I am at my whits end here! Lol every part is now new.
In my generation truck, you can't just plop in new encoder motors without calibrating them, you have to use a Tech-2.  What does your shop manual say?
What year to what year need to be programmed?
    250.3k
    TheStranger
    TheStranger
  • Who's Online   2 Members, 0 Anonymous, 1,553 Guests (See full list)
