Wanted to share my experience w/ this stupid GM mandate. After going round & round w/ my dealer & getting management involved I was finally able to get the dealer to implement #21-NA-228, Oct 21, 2021 & disable the idle timeout. Initially service stated they were unable to perform this per GM. It took 1 hr 34 min (I watched) & ridiculous $189+, but my truck will run for as long as I want now. Don’t quit if they tell you no, it is possible.
good to know, its getting to the point that they need to offer a programming option when you buy a new vehicle. not every ones driving habits are the same as the engineering team at the manufacturer
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
