A bit new to this hands on in this section but had some questions just to make  sure. If facing the truck that bolt should be removed to the left ? And also the truck is 17 Silverado so why is it not budging off I’ve tried dewalt impact gun, 1/2 drive 20 inch long breaker bar 24mm socket. Also I have access the flywheel area and also have it locked to stop it from turning anybody got why or a better way ?
They are torqued to like 200+ foot lbs with some sort of factory lock-tite on there.
Put a jack handle on your breaker bar or get a stronger impact gun. You can also heat the bolt up with a propane torch for a few minutes as well, just make sure to only heat the bolt and nothing else.
There is a rubber seal on the front timing cover. It's just fine if you heat up the head of the bolt.
600 lb impact wrench ( Failed ) 1000 lb impact wrench ( Failed ) next attempting 1500 lb impact wrench gun tomorrow - breaker bar with 3 ft pipe ( Failed ) someone told me about a heavy duty crank sockets so am throwing that in the mix with the 1500 lb impact wrench gun tomorrow today was a failure of try’s. We’ll see if 1500lbs can remove that bolt with that dam loctite!
Battery, chorded, or pneumatic impact?  If the latter, make sure there's enough air in the tank.  I have a 1300 ft-lb pneumatic Kobalt, and it has never met a fastener it couldn't remove; driveaxle bolts on a Jetta are over 300 ft-lbs AND glued with red loctite.  I tried jacking up the end of a breaker bar to use vehicle weight as the force to remove a Jetta axle bolt, but the bar bowed and lifted the wheel off the ground before snapping the breaker's trunnion (pretty incredible to see the jack lifting 800 lbs from 18" away).  With 150 psi in the tank, the impact zipped the bolts out like they weren't even torqued.  The gland nut on an ACVW engine is torqued to 253 ft-lbs, and my impact lights those off instantly as well.
You could try a torque multiplier, something like this, if you need:
https://www.northerntool.com/shop/tools/product_200732635_200732635
https://www.toolplanet.com/product/Neiko-Pro-Torque-Wrench-Multiplier/torque-wrench
Your FLAPS may have a loaner/rental.
Edited by 16LT4
Thanks never seen those products with my google search from hell and back if those tools are hitting high loosen torque values like it says then they are hitting higher than the impact am about to pick up 1500 lbs. I sprayed brake cleaner last night herd rumors that it breaks the red devils loctite. I’ve never ran into anything this tight before it’s really kicking my ass right now and am doing all this just to install the MF supercharger ! And come to find out it has a extra pulley I had to add on top of the HM BLR pulley this is holding up all other left over installation to get the truck back and running. But any information helps me guys thank you
How long do you have to heat the bolt if I go for heating it and also do y’all think the bolt is reversed threaded and have to turn to the right the bolt torwards driver side ?
2 hours ago, shakenfake said:
You shouldn't need to heat the bolt. impact gun that mfer off
Agreed.  If an impact can't remove a red loctited 300 ft-lb bolt, it is a piece of garbage.
Rod cap bolts on a Lugger 18L I-6 are 650 ft-lbs (Cummins V12 is 690 ft-lbs, IIRC), and we get those on and off without issue.  Just keep that in perspective... 😉
On 1/25/2022 at 3:02 PM, rlcole321 said:
Also note, that is a "Torque to Yield" bolt and CANNOT be reused!
Sure it can lol. You just have to not care enough to replace it, which happens all the time.
If everyone followed the TTY stuff you'd have to replace more than half the bolts you take off the vehicle to do any service work.
  • Haha 1
Update heavy duty socket 24 mm with 1200 lbs torque Milwaukee impact wrench worked. Honestly it had a lot of loctite factory glue  and I believe the socket made it work it’s so dam heavy too of all the things you can try only this combination worked for me but mission accomplished thanks every one for the advice.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 804 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
