There is this thread on that topic.
 The sensor is directly to the left of the top bell housing bolt in this picture. I don't have a way to circle the image.
If you lay on top of the engine, with your left hand you can pull the wiring harness 1in wich give you enough space to get the socket (1⅙ Or 27MM) with an extension on the sensorIMG_20220201_154950586.thumb.jpg.0d2a4dfbb8678a6837ac13bc588c3f20.jpg
