I have had this truck since September and continue to get these OnStar poorly descriptive alert(see below). And the dealer can’t seem to figure it out. Anyone else getting these alerts or do I need to pursue the lemon law??
thanks in advance
JP
An issue with the Engine and Transmission System in your 2021 Chevrolet Silverado has been detected. Please service your vehicle within 1 day.
Please disregard this message if your vehicle is already in for service. Inaccurate notifications can be generated during service.
Please see your dealer for service.
Edited by JP33
First thing I did was turn off OnStar, If your truck is having an issue you should get a message on the dash.
Lemon law, with no issues with the truck? That will be a tough one to win. More like slim to none, and slim has already left town.
The only thing I get is the check engine light goes on. Nothing else first I was told it’s a chafed wire but they couldn’t find it, now they tell me it’s the fuel lines both hi pressure and return which they ordered but are on back order. Can’t wait to see what’s next
Haha funny guy!! 😃Yea yea I know. But ridiculous they don’t know what it is
Personally, I would take it to another dealer. Your truck is not married to the lot you bought it from.
It will be harder now since they have started warranty work, but it is still possible to find someone who will inherit their work.
Would also suggest opening a claim with GM about what is going on, then if you do eventually go the LL route, you have everything documented.
Edited by JimCost2014
thanks in advance
JP
Lemon law?  For an OnStar alert?  Good lord...
If there are no codes in the truck, current or history, in ANY module, just drive it and ignore the warnings.
Agreed but once the idiot light comes on a lot of services don’t work like remote start etc so it’s a PITA
So the check engine light is coming on?  There should be codes then.
Stated it was P2635 in this thread:
If he still has that code and the dealer didn't follow the diag or the PI, then he needs to take it in and have them diag and follow the DTC and the PI.
#PIP5788A: DTC P2635 Set - (Apr 19, 2021)
Subject: DTC P2635 Set
Involved Region or Country
North America
Condition
Some customers may comment that the SES lamp is illuminated or was Illuminated and turned off, with no drivability concerns. During inspection Technician may notice DTC P2635.
Cause
Unknown at this time
Correction
If you encounter a vehicle with the above DTC, follow the applicable diagnostic flow chart in service information for further diagnosis and repair.
If the diagnostic does not isolate the concern, replace fuel feed pipe (fuel line between the high-pressure fuel pump and chassis line), clear the codes, and return it to the customer.
If the truck has already had the fuel jumper replaced, do not replace again. Follow diagnostic flow chart to ensure a different issue has not developed.
If it does not isolate the concern, clear codes only and return to the custom.
Engineering knows about the concern and is working on a more permanent service procedure.
This PI will be updated as information is gathered.
DTC P2635
Diagnostic Instructions
Perform the Diagnostic System Check prior to using this diagnostic procedure: Diagnostic System Check - Vehicle
Review the description of Strategy Based Diagnosis: Strategy Based Diagnosis
An overview of each diagnostic category can be found here: Diagnostic Procedure Instructions
DTC Descriptor
DTC P2635
Fuel Pump Flow Performance
Diagnostic Fault Information
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Control Circuit Shorted to Control Circuit
Control — Terminal 1 @ A6C Fuel Pump and Level Sensor Assembly - Primary
P102A
P1029
P102B
P102C, P2635
Control — Terminal 2 @ A6C Fuel Pump and Level Sensor Assembly - Primary
P102A
P1029
P102B
P102C, P2635
Control — Terminal 3 @ A6C Fuel Pump and Level Sensor Assembly - Primary
P102A
P1029
P102B
P102C, P2635
Circuit/System Description
For an overview of the component/system, refer to: Fuel System Description
Circuit
Description
Control
The output circuit varies between ground and 12 V.
Component
Description
G12 Fuel Pump
The component has a 3-phase motor. The control module converts the DC voltage from the battery to 3-phase AC to power the motor.
K111 Fuel Pump Driver Control Module
The control module K111 supplies the fuel pump with a PWM signal in order to achieve the desired fuel line pressure.
When the ignition is turned On, the ECM sends a 12 V signal to the control module K111 to enable the fuel pump. If the engine is not started, the control module K111 turns the fuel pump Off after 6 s.
Conditions for Running the DTC
DTC P018B, P018C, P018D, P0641, P064A, P0606, P1029, P102A, P102B, P102C, P1255, P129F, P12A6 = Not set
Fuel Pump Command = On
Ignition Voltage — 11 to 32 V
Engine Run Time — Greater than 30 s
Fuel Level Sensor — Greater than 10%
Frequency the DTC runs = Continuously — After the running conditions are met — For greater than 1 s
Conditions for Setting the DTC
The difference between the following parameters is greater than a predefined value:
Desired Fuel Pressure
Fuel Pressure Sensor
Actions Taken When the DTC Sets
DTCs listed in the DTC Descriptor Category = Type B DTC
Conditions for Clearing the DTC
Reference Information
Schematic Reference
Engine Controls Schematics
Connector End View Reference
Master Electrical Component List
Electrical Information Reference
Circuit Testing
Connector Repairs
Testing for Intermittent Conditions and Poor Connections
Wiring Repairs
DTC Type Reference
Powertrain Diagnostic Trouble Code (DTC) Type Definitions
Scan Tool Reference
Control Module References
Circuit/System Verification
Note: Do NOT replace the control module if DTC P2635 is set.
Ignition » On / Vehicle » In Service Mode
Verify DTC U0074, U18A2 is not set as a history DTC.If DTC U0074, U18A2 is set
Refer to: Diagnostic Trouble Code (DTC) List - Vehicle
If DTC U0074, U18A2 is not set
Verify DTC P018B, P018C, P018D, P0231, P0232, P023F is not set.If DTC P018B, P018C, P018D, P1029, P102A, P102B, P102C is set
If DTC P018B, P018C, P018D, P1029, P102A, P102B, P102C is not set
Perform the scan tool control function: Fuel Pressure » Increase — 300 kPa (43.5 PSI)
Verify the following parameters are within 45 kPa (6.5 PSI) of each other:
If not within 45 kPa (6.5 PSI) of each other
Refer to: Fuel System Diagnosis
If within 45 kPa (6.5 PSI) of each other
Perform the scan tool control function: Fuel Rail Pressure » Increase — 400 kPa (58 PSI)
Verify the following parameters are within 60 kPa (8.7 PSI) of each other:
If not within 60 kPa (8.7 PSI) of each other
If within 60 kPa (8.7 PSI) of each other
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Verify the DTC does not set.If the DTC sets
If the DTC does not set
All OK.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the repair: Diagnostic Repair Verification
It would look like you need to find a dealer who knows how to work on your truck and the issues.
Have them look in the left front where the harness comes from the ECM. I'm willing to put a small wager the casing on the harness has rubbed through and the wiring is all corroded and braking.
Thanks
They had previously checked for chafed wire, I presume that’s at the ECM but not sure and found nothing so they recently did fuel hoses and so far so good. Hope so as I have a 1300 mile round trip road-trip planned soon.
Edited by JP33
On 3/17/2022 at 3:07 PM, newdude said:
Thanks
they replaced the fuel hoses and it seems to have worked so far
North America
Condition
Cause
Correction
DTC P2635
DTC Descriptor
DTC P2635
Circuit
Short to Ground
Short to Voltage
P102A
P1029
P102B
P102C, P2635
P102A
P1029
P102B
P102C, P2635
P102A
P1029
P102B
P102C, P2635
Circuit
Description
Control
Component
Description
G12 Fuel Pump
Schematic Reference
Circuit Testing
Connector Repairs
Wiring Repairs
DTC Type Reference
Scan Tool Reference
All OK.
Repair Instructions
    JimmyB4
    JimmyB4
  • Who's Online   2 Members, 0 Anonymous, 728 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
