I have had this truck since September and continue to get these OnStar poorly descriptive alert(see below). And the dealer can’t seem to figure it out. Anyone else getting these alerts or do I need to pursue the lemon law??
thanks in advance
JP
An issue with the Engine and Transmission System in your 2021 Chevrolet Silverado has been detected. Please service your vehicle within 1 day.
Please disregard this message if your vehicle is already in for service. Inaccurate notifications can be generated during service.
Please see your dealer for service.
Edited by JP33
First thing I did was turn off OnStar, If your truck is having an issue you should get a message on the dash.
Lemon law, with no issues with the truck? That will be a tough one to win. More like slim to none, and slim has already left town.
The only thing I get is the check engine light goes on. Nothing else first I was told it’s a chafed wire but they couldn’t find it, now they tell me it’s the fuel lines both hi pressure and return which they ordered but are on back order. Can’t wait to see what’s next
Haha funny guy!! 😃Yea yea I know. But ridiculous they don’t know what it is
Personally, I would take it to another dealer. Your truck is not married to the lot you bought it from.
It will be harder now since they have started warranty work, but it is still possible to find someone who will inherit their work.
Would also suggest opening a claim with GM about what is going on, then if you do eventually go the LL route, you have everything documented.
Edited by JimCost2014
thanks in advance
JP
Lemon law?  For an OnStar alert?  Good lord...
If there are no codes in the truck, current or history, in ANY module, just drive it and ignore the warnings.
Agreed but once the idiot light comes on a lot of services don’t work like remote start etc so it’s a PITA
So the check engine light is coming on?  There should be codes then.
Stated it was P2635 in this thread:
If he still has that code and the dealer didn't follow the diag or the PI, then he needs to take it in and have them diag and follow the DTC and the PI.
#PIP5788A: DTC P2635 Set - (Apr 19, 2021)
Subject: DTC P2635 Set
Involved Region or Country
North America
Condition
Some customers may comment that the SES lamp is illuminated or was Illuminated and turned off, with no drivability concerns. During inspection Technician may notice DTC P2635.
Cause
Unknown at this time
Correction
If you encounter a vehicle with the above DTC, follow the applicable diagnostic flow chart in service information for further diagnosis and repair.
If the diagnostic does not isolate the concern, replace fuel feed pipe (fuel line between the high-pressure fuel pump and chassis line), clear the codes, and return it to the customer.
If the truck has already had the fuel jumper replaced, do not replace again. Follow diagnostic flow chart to ensure a different issue has not developed.
If it does not isolate the concern, clear codes only and return to the custom.
Engineering knows about the concern and is working on a more permanent service procedure.
This PI will be updated as information is gathered.
DTC P2635
Diagnostic Instructions
Perform the Diagnostic System Check prior to using this diagnostic procedure: Diagnostic System Check - Vehicle
Review the description of Strategy Based Diagnosis: Strategy Based Diagnosis
An overview of each diagnostic category can be found here: Diagnostic Procedure Instructions
DTC Descriptor
DTC P2635
Fuel Pump Flow Performance
Diagnostic Fault Information
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Control Circuit Shorted to Control Circuit
Control — Terminal 1 @ A6C Fuel Pump and Level Sensor Assembly - Primary
P102A
P1029
P102B
P102C, P2635
Control — Terminal 2 @ A6C Fuel Pump and Level Sensor Assembly - Primary
P102A
P1029
P102B
P102C, P2635
Control — Terminal 3 @ A6C Fuel Pump and Level Sensor Assembly - Primary
P102A
P1029
P102B
P102C, P2635
Circuit/System Description
For an overview of the component/system, refer to: Fuel System Description
Circuit
Description
Control
The output circuit varies between ground and 12 V.
Component
Description
G12 Fuel Pump
The component has a 3-phase motor. The control module converts the DC voltage from the battery to 3-phase AC to power the motor.
K111 Fuel Pump Driver Control Module
The control module K111 supplies the fuel pump with a PWM signal in order to achieve the desired fuel line pressure.
When the ignition is turned On, the ECM sends a 12 V signal to the control module K111 to enable the fuel pump. If the engine is not started, the control module K111 turns the fuel pump Off after 6 s.
Conditions for Running the DTC
DTC P018B, P018C, P018D, P0641, P064A, P0606, P1029, P102A, P102B, P102C, P1255, P129F, P12A6 = Not set
Fuel Pump Command = On
Ignition Voltage — 11 to 32 V
Engine Run Time — Greater than 30 s
Fuel Level Sensor — Greater than 10%
Frequency the DTC runs = Continuously — After the running conditions are met — For greater than 1 s
Conditions for Setting the DTC
The difference between the following parameters is greater than a predefined value:
Desired Fuel Pressure
Fuel Pressure Sensor
Actions Taken When the DTC Sets
DTCs listed in the DTC Descriptor Category = Type B DTC
Conditions for Clearing the DTC
Reference Information
Schematic Reference
Engine Controls Schematics
Connector End View Reference
Master Electrical Component List
Electrical Information Reference
Circuit Testing
Connector Repairs
Testing for Intermittent Conditions and Poor Connections
Wiring Repairs
DTC Type Reference
Powertrain Diagnostic Trouble Code (DTC) Type Definitions
Scan Tool Reference
Control Module References
Circuit/System Verification
Note: Do NOT replace the control module if DTC P2635 is set.
Ignition » On / Vehicle » In Service Mode
Verify DTC U0074, U18A2 is not set as a history DTC.If DTC U0074, U18A2 is set
Refer to: Diagnostic Trouble Code (DTC) List - Vehicle
If DTC U0074, U18A2 is not set
Verify DTC P018B, P018C, P018D, P0231, P0232, P023F is not set.If DTC P018B, P018C, P018D, P1029, P102A, P102B, P102C is set
If DTC P018B, P018C, P018D, P1029, P102A, P102B, P102C is not set
Perform the scan tool control function: Fuel Pressure » Increase — 300 kPa (43.5 PSI)
Verify the following parameters are within 45 kPa (6.5 PSI) of each other:
If not within 45 kPa (6.5 PSI) of each other
Refer to: Fuel System Diagnosis
If within 45 kPa (6.5 PSI) of each other
Perform the scan tool control function: Fuel Rail Pressure » Increase — 400 kPa (58 PSI)
Verify the following parameters are within 60 kPa (8.7 PSI) of each other:
If not within 60 kPa (8.7 PSI) of each other
If within 60 kPa (8.7 PSI) of each other
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Verify the DTC does not set.If the DTC sets
If the DTC does not set
All OK.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the repair: Diagnostic Repair Verification
  • Thanks 1
It would look like you need to find a dealer who knows how to work on your truck and the issues.
  • 1 month later...
Have them look in the left front where the harness comes from the ECM. I'm willing to put a small wager the casing on the harness has rubbed through and the wiring is all corroded and braking.
Thanks
They had previously checked for chafed wire, I presume that’s at the ECM but not sure and found nothing so they recently did fuel hoses and so far so good. Hope so as I have a 1300 mile round trip road-trip planned soon.
Edited by JP33
On 3/17/2022 at 3:07 PM, newdude said:
Thanks
they replaced the fuel hoses and it seems to have worked so far
North America
Condition
Cause
Correction
DTC P2635
DTC Descriptor
DTC P2635
Circuit
Short to Ground
Short to Voltage
P102A
P1029
P102B
P102C, P2635
P102A
P1029
P102B
P102C, P2635
P102A
P1029
P102B
P102C, P2635
Circuit
Description
Control
Component
Description
G12 Fuel Pump
Schematic Reference
Circuit Testing
Connector Repairs
Wiring Repairs
DTC Type Reference
Scan Tool Reference
All OK.
Repair Instructions
    jgaudet99
    jgaudet99
  • Who's Online   4 Members, 0 Anonymous, 532 Guests (See full list)
