IMG_0180.HEICIMG_0178.HEICIMG_0063.HEIC
So I recently purchased a used 2018 GMC which had a Retrax cover.  Unfortunately, I think there may have been some issues with it in the past and am trying to fix the installation.  I understand some water will get in the bed, but it seems to be more than normal when it rains.  I have had other covers in the past and know that some water will almost always get in.
I have attached several pictures and videos and hopefully you guys can help guide me in what I need to do.
There seems to be a lot of play when the cover is closed and locked on the back right of the cover (non locking side) which makes a gap between the tailgate and cover.  When looking at that rail it seems there is a little indention from the clasp that closes the cover...I am not sure if this is normal and included in one of the pictures.  I did measure and the spacing is 1/8" from rail to tailgate, but since there is play it seems to affect it.
I am also getting water in from the front and sides.  The space between the cover and top of the box seems to be a decent size gap too.
Any advice would greatly be appreciated.
Thanks,
My Retrax cover has white plastic set screws on either side of the clamps. I don't see any in your pictures but if there are some, tightening them may reduce the gap between the rails and the main section of the cover and make it seal better. When I installed mine it took quite a bit of messing around with it to get everything lined up and functioning right. maybe try removing the clamps and see if you can get everything positioned better.
First good luck. I have been sorely disappointed in my Retrax and would not but another one, especially considering the comparative cost. But to your concerns.
The indention looks like it could be caused be the little spike that locks the cover to the rail. When closed, there really shouldn't be much play in the top. The bolt in the picture sticking out from the rail hold the cover in the fully closed position.
From the pictures and your description, your rail(s) need to be solid toward the tailgate. That should help cost the gap at the tailgate.
Now, that gap in the front. I bought a cover late 2017 when I bought my truck. It didn't have a gap there, ever. Ended up getting a warranty replacement for water intrusion through the rubber seals between the slats. Now I have a gap at the front. It appears they changed the length of the cover (warranty replaced cover only, not rails). No clue how to fix. I need to take my cover back off and I intend to put something to cover the hole in the back of the canister. When it rains and I'm driving the front wall of my bed gets completely soaked from wind driving rain through that gap and out the bank of the canister.
For water around the edges of the bed. This ticks me off now than anything and should have been solved by rail design, but it's not and I'm not certain there's a good way to keep it working long term. When installing the rails, you actually have to twist the rails up, to secure them at an forward angle. This directs water that gets in the channel where the wheels run to for away from the bed. Don't worry, due to surface tension it'll still hug the cover and drip down some in your bed. You'll really need the white nylon studs mentioned earlier to get this right. They actually updated their instructions at find point; the original printed instructions that came with my cover didn't mention it.
Good luck!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
