@J Lake Concentrate on the grounds. The majority of electrical problems are a result of bad grounds on these. The negative battery cable is a good place to start. Check the resistance on that one. Make sure to wiggle the cable while you do it. Also along frame rail just behind front passenger tire, you will find another one. Remove that, scrape the mounting point clean as well as the connector on the cable and reattach. Another is IIRC, on the firewall towards the driver's side engine ground strap that gets corroded. That may need to be replaced. Hopefully you can track down the problem. Although these have already been mentioned, it's still worth checking.
Edited by mikeyk101
Hello wveryone, my truck started doing the same.  Shuts off/on occasionally when I turn.  Completely loss of power but gurgles back on.  I travel often and this can strand me or worse cause an accident. Has anyone found that smoking gun or are we all still screwed with this problem?  I also have already replaced my transmission and several other drive train parts.  I am a Chevy man but these issues are beginning to wave my faith in them and considering other brands.
My daughters 2015 started having the same issue - shutting off while turning at low rpm’s. I cleaned all grounds as the Service bulletin suggests, but also cleaned the 2 main grounds on the engine, drivers side, one just above the vacuum pump. Coincidentally she had just had the vacuum pump replaced before it started shutting off. I suspect the ground was taken off and not clean when it was put back on. Anyway, problem solved, not sure which of the many grounds was the problem.
https://static.nhtsa.gov/odi/tsbs/2017/MC-10113356-9999.pdf
    tblt44
    tblt44
  • Who's Online   7 Members, 0 Anonymous, 479 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
