the truck has made the rattle since march
my truck went into the shop in mid march
and they replaced valve body , transmission control module, and the transfer case actuator
and just got it back a week ago and it’s still makes this random rattle at idle
How loud is the sound with the hood open?
Any low hanging wires that might be contacting a skid plate or something? Kind of sounds like plastic hitting metal or something.
was finally able to duplicate it at the dealer with the shop foreman and service advisor
the rattle starts when going over a spend bump
and also made the same rattle when I shut the engine off
and when I closed the door , it made the same rattle
taking it in on tuesday
2 hours ago, Bob’s Sierra said:
can’t make this up
a rock for inside of the transmission mount and was causing the rattle
Wow give your service writer a pat on the back if that actually fixes it. How the hell did they chase it to the trans mount, give that mechanic a pat on the back too! Most dealers just eye rolled me anytime i would have a rattle complaint lol.
the head tech of the shop
got it on the lift , pinpointed the noise from transmission
used a pry bar to find exactly where it was
removed the mount and it was inside the mount and completely worn down and polished smooth
