I can’t find it anywhere but what’s the replacement part # or even carriage bolt size for the 18 Silverado 1500 tow hook bolt, the one you have to cut off to get out.
Just wanna know sizing or replacement part # from gm
thanks
Watch this video.  If you do this, when you re-installing it, put the bolt in from the other side & put the nut on the inside.
Edited by rav3
thanks
Are you puting on a different set of hooks? They give you new bolts when you buy the factory OEM ones.
