Does anyone know where I could find the headlight harness wiring-pin diagram for 22-Silverado LT like the one attached; the one shown has 8 pins and mine has 12? I need to posi-tap into L/R turn signal & L-park for AVS-Lightshield pro bug reflector. Any suggestions?
  • 5 months later...
Hello I would like to know how you solved it. I have 21 silverado with 8pin and need to convert it to 22 silverado headlights with 12 pin like the one you have in above picture
Edited by SgS
I just bought the AVS Aeroskin Lightshield PRO and could not for the life of me figure out what wires to tap into, so I wanted to share my results with anyone else looking for information on this.
2023 GMC Sierra 1500 - 12 Pin Headlamp Harness
[Ground] Black Wire on Black Wire (Slot 1 Drivers Side)
[Parking Lights] Brown Wire on Blue/White Wire (Slot 5 Drivers Side)
[Left Turn Signal] Yellow Wire on Blue/White Wire (Slot 7 Drivers Side)
[Right Turn Signal] Green Wire on Blue/White Wire (Slot 7 Passenger Side)
I would rely more on the slot number vs color, but you can test each slot with a voltmeter to be sure.
This is if you have the pin unplugged and you're looking at the flat end with the red tab on top. Slot 1 would be the top right, 6 is top left, 7 is bottom right and 12 is bottom left. Hopefully this helps someone else out since the instructions don't.
  • 5 months later...
For anyone struggling with the Illuminated GMC grill badge having an 8 pin connector while the head light has a 12 pin connector below are the two wires I successfully tapped into to make it work.
2025 GMC Sierra 2500HD Denali Ultimate
12pin driver side head light harness
Pin #1 Black = GND
Pin #6 White/Yellow Stripe = Running Lights
Tip: Turn the wheel to the right and remove 5 of the wheel tub screws. And fold tub enough to get at harness.
Can someone help me with the wiring hardness connector on a 2015 GMC sierra 1500 with the led headlights on passenger side please
connector broke and I need the wiring pattern
you posted in the wrong section, this is for completely different trucks than yours is.
    jl6690506
    jl6690506
  • Who's Online   5 Members, 1 Anonymous, 1,095 Guests (See full list)
