My 2000 Silverado blows cold air until the engine is revved. When the vehicle is started it will blow cold air low side at 32psi 70* ambient temp, High side around 150. When I rev it up the high side will come up to around 200 psi and the compressor will kick out and won't start again until I shut the engine off and restart it. I have by passed the low pressure switch at the dryer, High Pressure switch at the compressor and the one leaving the condenser with no change.
32 and 150 pounds for 70F are normal. But 200 when you rev to the point it cuts out is not. Do not bypass the pressure switches, especially after you discovered the high side cranks out 200 pounds. Pressure switches are not a computer nanny. They are very, very necessary. If you need to bypass them as part of troubleshooting, only do it after you confirm the pressure ranges are normal. You run the risk of over pressuring parts of the system, blowing seals etc.
Has any work been done to the AC like new gas or a gas top up? Does the condenser fan cycle and can the condenser get good air flow? Does the compressors clutch cycle properly? Or does it just engage and stay engaged? If it cycles properly, there is a chance theres a restriction somewhere. When the high side goes to 200, what happens to the low side pressure?
Stu has good advice. it could also be a bad relay or weak compressor clutch. check the voltage and the ground at the compressor. a scan tool that does live data can tell you if the compressor is comanded on by the bcm
My 2013 GMC Denali is doing the same thing. At 103* ambient temp my pressures are 40-45 on low side and 140-150 on high side. I just got it back from the shop and they said it did not have any r134 in it. He said the filled it with 2 cans r134 and the idle pressures are normal. While taking off from a stop you can feel the air cut off then once you maintain normal throttle pressure it gets cold again.
any help will be appreciated.
idle pressures normal but what about off idle? either the charge is still low or under hard acceleration it's normal for the ecm to shut the compressor off. this is why you recharge by weight not pressures
I plugged back into it today at 70* ambient temp. Before starting the truck I had 72psi on the high and low side. Running I had 25 psi  low and 145 psi high. When I gave it throttle the low side dropped to around 22 and high side went to 160. After the idle came back the compressor kicked back in. Which it wasn't doing the other day. We did remove a bit of freon.
you have a low charge now. time to start over, evacuate the system and charge with the correct freon weight, add a tracer dye in case you have a leak
No oil is lost during the vacuum process. Adding dye to the system at this time is a great idea.
you may lose some oil during evacuation. if you use a recovery machine it will capture and measure the recovered oil so it can be replenished. you may find a local garage that will do the recovery for free if you are doing the vacuum and recharge yourself. some recovery machines also weigh the recovered freon
Thanks for the info. Is there a tag somewhere in the engine compartment that says how many oz. should be put in?
On mine the sticker is on the radiator support. I was planning to do the recovery myself with a vacuum pump and scale, and recover the Freon into a recovery can. I wouldn’t mind having some HVAC tools for future projects.
if you have a vacuum pump that will do that go for it. all the vacuum pumps I've owned vent to the atmosphere
you can buy PAG oil with dye already in it, check service manual for viscosity.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 1,056 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
