Sand/salt spreader hook up
Anyone got a SAND/SALT spreader set up? The one I want needs 30 amps to run the vibrator and spreader. I'm wondering if my truck can handle this.
JHM..........If you have the factory tow pkg. on your truck a GM I
assume. You should have a hot lead in the trailer plug.
Sometimes you have to add a fuse in the underhood fuse center
to make it work. Dumb GM didn't usually put one in there.
Read the owners manual for amp rating max..
I run a Western ultramount setup.......geo
Hey I assume you are a "plowhead" me too and a few other guys
here. Check out these snowplow sites. Lots of helpful folks there !
http://www.plowsite.com
http://www.snowplowing-contractors.com/forums
Power connects directly to battery with remote control module connecting to a fuse powered when ignition is on.
