Yes, they did come painted from the factory but only on higher trims. I found painted door handles for my 2012 because that was way cheaper than having a place paint some for me.
Usually Ebay was the best place to find them.
Check Ebay for body color handles...include Silverado, Sierra, Escalade, Avalanche, Tahoe, and Yukon models in your search...they all use the same handles (Chevy will have one name for a color, while GMC has another name for the same color--Chevy has Victory Red, while GMC has Fire Red, yet they are both the same color)
People on Ebay are selling colored handles using the Chrome part numbers.  Apparently, they think they are new but they are take offs from people changing to chrome handles.
