So I’m still looking at this, and still finding few options. I’m reconsidering now going to a 275/60r22. No additional width, so I think it avoids the upper control arm issue. 35.0” diameter, so 1.1” larger in radius than OEM. So that leaves me with two questions for anyone that may have this setup.
1) Does it fit without any rubbing at full suspension compression? I have no way to measure this.
2) What kind of fuel mileage hit did you take city/highway moving to an E load range tire? I have the 6.2. OEMs are 41#, the Michelins in this size are 59#. That’s a lot more rotational mass.
That much weight is over double the empty truck. Sure the truck can handle it well, comfortably even, but it significantly increases braking distances regardless of trailer brakes and slows acceleration and adds significant surface area to a wind. "Not noticing it" is a huge exaggeration. I'm sure you feel it every time you stop, change lanes, accelerate or hit a bump.
