I changed out the factory rear brakes for a Powerstop kit today and adjusted the parking brake shoes per the factory manual using a Gearwrench brake resetting guage. The rotors cleared with no dragging during reassembly.
After reassembly, the parking brake pedal is very tight and I barely get 1-2 clicks before it's set. The parking brake holds but I'm concerned with the lack of pedal travel.
The repair procedure calls for adjusting the shoes then adjust cable tension. I'm familiar with the cable tension adjuster on the lower frame rail but the factory procedure references a self adjuster lock-out pin which must be removed with no picture showing location.
Any help is appreciated.
Edited by alvocado
I'd probably just adjust the shoes in a little bit to give the pedal more travel before doing anything else. I prefer that the parking brake starts to full engage past 1/4 of the way down and be basically hard to push by 3/4.
We have to disable the adjuster before messing with the shoes, then enable it and set/release it 3 times to set it.
The clearance between the drum and shoe is supposed to be set at ..026 inches.
The hole for the lockout pin is on the side, you have to lift up the parking brake lever to access the internal part to slide the screwdriver/lockout pin into it.
I pulled the rotors and adjusted the shoes in a bit using the brake shoe caliper to set both sides equally. The pedal now stops at the half way point and holds tightly.
I don't think the factory procedure is accurate because setting to .026 in doesn't allow for any travel on the pedal. I recommend others leave at least 1/6" of inch gap vs. the inside rotor diameter to avoid pulling the brakes for a second adjustment.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 5,964 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
