Hello all,
I am in some desperate need of advice on my next tow vehicle. I’m decking between a 2000 Chevy 3500 4x4 with the 6.5 td or a 2008 Chevy 3500 wt with the 6.0 2wd. Both are dually’s as that’s what I need. I tow a travel trailer that loaded eights around 9500lbs and is 40 feet long. Pros and cons with both would be nice as well as any experience with either towing this kind of weight. Current tow vehicle is a 6.0 powerstroke and tows the weight just fine, but it’s a single rear wheel so it blows all over the highway.
2 hours ago, Tmmoll said:
Hello all,
If you don't have air bags on the rear on your current you should check it to them.
Thought about it, but suspension is only part of my issue. The real problem is the length. I have all my weight distribution set up correct and it drives pretty good unless a truck passes or it’s a windy day.
The gas 6.0 is a proven workhorse engine. It's going to get 6-8mpg towing that heavy but it's a lot cheaper than diesel right now.
The 6.5 Turbo Diesel isn't that power of an engine and finding parts and doing repairs isn't as easy because it's such an old engine now.
Stay away from the 6.5TD for towing. That engine was optimized for fuel mileage, not power. You can build that engine up to respectable power and longevity, for lots of money.
The 6.0LS is designed for occasional towing, as it's a gas engine. And it's bulletproof if not abused.
Sounds like your mind is made up on a dually, so get the 2008. But that's only my opinion.
I've got an '03 K2500HD SRW, CC, with a 6.0LS that is rated to tow 9000 pounds.
Thanks all. My concerns are with the 6.5td was the lack of aftermarket support due to the age. I think I’ll be going with the 6.0l and keeping my travel trailer on the lighter side.
I wouldn’t bother to give you my family’s experience with the 6.5 being you check it off the list. Strangely your current 6.0 is probably the worst ford diesel for being problem free. The 6.0 gas has a stellar reputation. If you ever come across 7.3 diesel and can buy it. There’re bulletproof. Same with pre 2000 5.9. The Ford is better built overall compared to early Rams. The load will make itself known behind a gas verses diesel. I’m partial to the fifth wheel for the ultimate in safety.
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 1 Anonymous, 548 Guests (See full list)
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
    • We’ll have to agree to disagree. I didn’t experience or know anyone who had a decent car after 100K miles in the 60s through the 80s that were daily commuter vehicles. Unless they were collector vehicles. Of course things cost more due to inflation. But we also make more money. The biggest money drains these days are things people think they need today versus what we require back in the day. Like cell phones and internet as examples. Another example is where you live. Cost of living varies from state to state. I would need twice the money to live in NJ vs Texas in retirement. The car you recently purchased was less than my first car with inflation at 3000$ in 1973. I didn’t have air, electric windows, cruise etc. Purchasing power is equivalent, you just have to do the research.
