I have no power to the rear window and sunroof they are nor operating.
checked all fuses everything looks good any ideas? all other options working as they should be
Welcome to the site.
My guess is you have a broken/chaffed wire in loom running through your center console.
You can access it by opening the lid, runs through the hinge on the drivers side.
Just like you thought the wires at the console hinge drivers side cut the power to the sunroof and rear window and console charger. They installed a 24 " long wiring harness with plugs on both ends and a part # on it plain as day. I have a feeling they knew it was a design flaw!!!
Can you post the P/N they used?
Good to hear it was fixed, like your truck a lot by the way!
I have a club here on the site for our 100's.
Thanks for the invite. I'm not sure I got to the club for the hundred year truck earners? Maybe you can send me that link again? Love my Chevy it's been a good truck I'm a Chevy loyalist.
