Hi All,
I just rotated my tires and was looking on line at inexpensive relearn tools. They all seem to have a lot of reviews saying they didn’t work. Does anyone have a recommendation for a reliable relearn tool to use after a rotation?  I don’t need other programming capabilities as far as I know. I’ll get it done by the dealer or local tire shop this time but I’m thinking I’d like to have the tool. Thanks.
50 minutes ago, Makito said:
Thanks for the quick reply.
I called my local Discount Tire and they said just come through their air check line and they will do it. Took less than 5 minutes. I may just stick with that approach.
  • 1 month later...
I bought this autel from Amazon.  Put the extra TPMS in my trailer tires.  I can reset psi warning lights  for the front at 50 and rear at 40  for the truck as well as set calibrations for different tire sizes.  Works good as a relearn tool.
Autel MaxiTPMS TS508K TPMS Tool, 2023 Newest TPMS Relearn Tool with 8PCS 315MHz+433MHz Sensors, Updated of Autel TS408/501, Top TPMS Scanner for TPMS Reset/Activation/Program with Lifetime Update https://a.co/d/68nu6Hb
On 11/14/2022 at 8:18 PM, Makito said:
I have the same one, works great.  I also use it for my 2018 Malibu.  So handy to be able to rotate your tires and not have the pressures on the instrument panel all screwed up.
Edited by CT Chevy Connoisseur
  • 2 months later...
I have the orange colored version.
Very honestly it works well on single axle short trailers and hit or miss on dual axle longer trailers.
What always works (and much faster) - start the TPMS learn process, have a person in the cab to relay the tire learn status,  when the directions tell you which tire is next press the tire valve and let air out until the person in the cab lets you know the sensor has paired.  Move on to the next one.
  This is faster than the relearn tool as long as you have a decent air compressor to re-air 5-10 pounds in each tire.
  • 2 months later...
I have the orange version too and experienced the same thing. Works well for the truck but did not work on my dual axel trailer. Went to use the unit the other day and I hear rattling as I am carrying to the truck
and no lights. Open up the battery compartment and both battery contacts have become disconnected from the board. Must have been cold solider joints. So I opened up the unit and resoldered the contacts and all is well. Strange that this happened over the winter????
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
