GMCustomerService bot usefulness
3 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
So every now and then I see a number of responses pop up from this useless bot telling members that this (the problem reported in their thread) is not what they want to hear and to contact GM via specific email address. I have never seen it post any kind of usefully or helpful advice in ANY thread and EVERY SINGLE POST always says the exact same thing other than changing the name in the body to the name of OP of thread. I also have never seen any updates where someone actually replied to the email and received help. Everytime I see a post by this bot, all I can think about is that it's just a PR gimmick and GM is just trying to present the illusion that they "care" and are trying to "help".
So has anyone ever contacted them using the email route and actually been helped with a resolution??? I'm guessing that it ends up just like a customer reaching out to any other large corporation and nothing happens.
It just bugs me everytime I see one of these posts. I think I just have way too much time on my hands...
I replied back to that bot and got banned!
I hope the same does not happen to you bro.  I too saw the post as useless and ridiculous. Makes no sense man.  It was some random oh that's just the normal Kind of response.
  • Sad 1
I just think that if customer service was so important to them that they have a "team" that also monitors social media, they could at least try and provide resolutions or useful advice in the thread. That would be way more helpful to other members on the forum.@GMCustomerService any response to this???
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,931 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
