So in Dec. 2018, with barely 20,000 miles on the truck, I got the dreaded (torque converter) shudder. I had the "3-flush" procedure with the Dex 6 . It did resolve the shudder at the time but annoyed that a few months later the TSB about a new Mobile 1 LV was not sent forwarded to me. Fast forward to Dec. 15th and, yep, full on return of the rumble strip shudder. Of course, I just saw the Service Bulletin 21-NA-199, dated Dec. 2021, that emphatically states the194 deg. thermal bypass valve should be replaced with a new 158 deg. version (Part #86774933). The bulletin states "Some customers may comment on one or more of the following conditions-blah, blah, blah...slip, vibration SHUDDER." Why would GM not inform Owners? Obviously they felt the transmission fluid was running too hot and contributing to mechanical failures. Since I live in South Florida I would have replaced it myself to maybe prevent the TC issue and save wear on my tranny. Well, I took it in to the dealer who said that since the 3-flush procedure did not resolve the issue that the TC has likely failed and needs to be replaced at a cost of $2,996 as the 5 year powertrain warranty expired 5/16/21. The truck only has 35,000 miles on the odometer. Comments? Suggestions? Have the system flushed again and see what gives? Contact GM Customer Service and see if they will fix it? A bit disappointing as I had also bought new a 2012 Silverado 1500 LT CC that I traded in for the current truck and I still own the 2003 Corvette Convertible that I bought new as well.
Comment.
If you want to keep it take it elsewhere and have it rebuilt with the sonnax zip kit. You'll be in for the same amount. Waiste money at gm and just
Wait for it..
A transmission shop shouldn't charge you $3,000 to replace the torque converter, I'd go there. Labor rates at dealerships have reached insane levels recently. Around here is $160-200 an hour and the techs are only making $25-35hr, talk about raking in the money. Years ago I was making just over 20 an hr with commission when labor rates were like $120hr and we still made money for the business, how times have changed in the past 10 years. End rant lol
I'm sorry, I'm unclear as to whether or not you ended up getting flushed and replaced with the new Mobil fluid that was supposedly designed to fix the problem. Apparently the previous fluid was too hygroscopic (attract water) and pulled water from the air in humid climates. I live in Arkansas and it's very humid here as well during the warm months. My truck got the shudder not long after they came out with the new fluid. The dealer for it flushed and switched over, and I haven't had a problem with it since. Figured I'd at least throw that out there in case you haven't got the new fluid. Would likely be a heck of a lot cheaper and worth a try.
Well I do know from my experience working at a Chevy dealership, when the shutter first starts they flush transmission system, if it occurs a few hundred miles after then torque converter was replaced. When I was there at the dealership, If the shutter came back after that then transmission had to be replaced. Best bet is since your truck is out of warranty, get a new transmission and make sure it comes with a new converter as well.
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 684 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
