Recently my 2005 2500HD 6.0L has had it's dash going crazy. Randomly, the ABS, airbag and brake lights will illuminate together with the ding chime. It sometimes accompanies the fuel gauge, oil pressure, and volt gauge going to zero and the battery light will come on. Sometimes the lights will quickly flash, other times they will stay on until I get to my destination. Seems to be worse during cold weather (below 20F). Trying to troubleshoot this. I've read it could be anything from a ground issue to a bad BCM or cluster. Anyone run into anything similar or have any tips/tricks?
Edited by 12dbsinad
Haven't seen this before, but be sure to start with the grounds. Make sure they're perfect before proceeding onto the next possible cause.
You might start with the grounds located on the wing off the frame, right below the driver's door.  Disconnect and clean both the frame, bolts and connetors, then reattach.
I would start with the fuses, check all of them.
I would also check ALL of the relays, with a relay tester. I just dealt with a similar issue with my wife's car. Turns out it was a relay going to an option that was not available on her model car. The relay for the "Bose Speaker/Woofer" was the culprit. I had a U0101 Code, Not communicating with TCM. As luck would have it the CAN (Controller Area Network) also runs through this circuit. Replaced relay and issue fixed. This was not on a GM vehicle, but the principle remains the same.
P.S. I got my Relay Tester off Amazon for about $12.
Like the above post states, start with that ground lug. If that doesnt resolve it start looking at battery cables and connections. from there pull the underhood electrical center up and inspect the bottom of it for rodent damage. (remove the 4 screws and pull the diagonal brace, release the tabs on the cover and lift it off and then the panel can be released and flipped up to expose the bottom)
Thank you all for the advise/help. I read another thread (not on this site) about a similar issue with a same vintage Tahoe having dash issues. Apparently there is a ground that affects the dash under the hood against the firewall that is a culprit of corrosion issues at the terminal, wire can still look attached but a slight tug and the wire pulled out of the terminal. Not sure if these trucks have that same ground but I will check that as well. Will also check relay/fuses. Drove the truck to and from work and to a appointment and never did it once but was fairly warm today (35-40f). My goal is to get it to do it, drive it in my shop and move ground bolts to see if it clears that way I have some sort of confirmation and not guessing. Again, thanks for the help and I will report back on updates so this thread can be as useful as possible.
Simplest first.. Do these grounds, and coat them with grease after.
  • 8 months later...
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 473 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
