matt6095 Posted March 2, 2023 Posted March 2, 2023 Looking for some questions I did a 53 swap to a 6.0 gen 3 LS motor they come in a 2000 GMC Sierra 1500 four-wheel drive I replaced the knock sensors crank shaft sensor I have fuel pressure at the injectors but I have no spark all the ground seem to be good any help or tips
Jsdirt Posted March 2, 2023 Posted March 2, 2023 (edited) So, the 6.0 is out of a '00 Sierra 1500. What was it put into? Edited March 2, 2023 by Jsdirt
CamGTP Posted March 3, 2023 Posted March 3, 2023 Make sure the coil pack harnesses are plugged in all the way and that you have the harness grounds connected. There is also a ground on the back on the cylinder head you want to make sure is hooked up.
Jsdirt Posted March 3, 2023 Posted March 3, 2023 He may have a tough time doing that if this is in a '74 Vega ...
Register a new accountSign in
