Hi All, I have a 2017 Silverado 1500 LT, and I am looking for aerosol paint to match the dark metallic paint that is on a bunch of the interior trim pieces. In this case, specifically the panel with the headlights, dimmer and 4WD controls on it. My RPO code sticker says 4AA on it, which should be Jet black, but I cant find anyone selling paint referencing this 4AA number. I have found "Jet Black" interior color paint on this site, and maybe some others, but the numbers not matching concerns me. https://www.paintscratch.com/touch_up_paint/Chevrolet/2017-Chevrolet-Silverado-Jet-Black-Interior-WA600R.html
Thank you for any help!
In case you are interested what I am working on, my truck did not come with the factory trailer brake controller, and I need to add one. Decided to try my hand at modifying the trim panel using a 3D printer, some plastic bond, and glazing putty to fit a Tekonsha Prodigy iD in the factory location. It wont match perfectly, but I think it will be in a good location and wont stand out too much.
20230330_192225.thumb.jpg.f6940a300d7eaceb073baeeb2e9cb474.jpg20230402_093701.thumb.jpg.28d1e5fb0feac5ee75c6465372500a93.jpg
I added trailer brake controls to the same panel. The factory color has a very fine metallic flake in it. When I painted mine, I first sprayed it with satin black and then I sprayed a very light dusting of metallic black from about 2-3 ft away.
Did you add the OEM or an aftermarket brake controller. If you added the OEM one, you would be the first person to successfully do that and many on this forum would be interested in how you got it done.
Are you trying to add the factory brake controller or are you planning on adding an aftermarket one to that panel?
Its aftermarket, it says it the post, it is a Tekonsha Prodigy iD. You can see the knob in the photos, it is not the factory slider.
I installed a Reese unit that mounts behind the dash and has a small dial/ button and an LED that I mounted in the dash panel.
  • 1 month later...
Just an update for anyone following along. Ended up working with my local autoparts store to mix a custom spray can to match. Its pretty close, close enough no one else is going to notice it unless they are looking for it or know that the trailer brake control knob isn't supposed to be there. Photo below of the mix he came up with. It has a little bit more black than the factory, and could use even a bit more flattening agent than the bunch that was already in there.
PLIKCGhr47kFadwnj6mTxVNikqGCsctsApaCwfoii4qt-ZQcM7SJ9u6Q8XSrZvXy3tCP481Q_OehAE9IORZcXmq-hmsKIFvtGR-nzVxKH1dO8g-jtJqx_ko6FS8bnOneAAx72RcgVGiC-psADJanXrW0RWVLjTuBte9XwdwKLI9uZeFFLIWTm8STfc3Ngba6-jURNBYqJQO6Wc_kkq9KCwth6hPGzUIZm75oIUuBwfQvFjN3ItA0h1NF9RXmNHTWpg-5WnU3pCQ-YcO11KmQ04Xbl86-B-fi0wAUA7cG2KyJriFVf7r9iyvMCU5lvn827t3IMwkKUytHryoN59QvEY87lzCD5X8D6pxa60gSl4X41soizbLdLu25zw0OVV43pwf30_5tJp8-79V_hEW1ebTZ1p28cFQKgJcukBs8LTle8n3zmtZYKmyxFR5m-21cuw4ZKIEsvBqgwKESo97w9Iu751HwqcgfO7oG1rtzew2WSJ8vIxEDmDgswoi4tAWlVamzYh4e--nWyyXVMaTnToQiabNowHqA3CVEQVV68m5M1E2ObZg7SMOdB2_dPWzb6eBHamwLIO7DIA__xyHE68X6ZM-ah76CB0LKEdaXnYEWaA2E2GTn_lLBAhehLYU9_X5EuZpt2BYKHWdArrhy5gnUJNipigZhjyndEKxCX4bmfj0NVO7BNz6gMC3Um1UlQHbWM1bAvY_A2KptJoySds8ADRQfcJDxF3oJsKOXJbkQ1Fhrb-1F9oF3o-mXqsTV0XYyZIq_FCq5C8uNn4m3W9qvdeSmNNokq790OJDtID1xV9wtG3ZTBi-FLs6YdP0NYTgc0htY4ZFRweIW2qgxIUg90KddYHPAM7n4T-PsHQ9BQSet3mY9K4sQRDCfDgOdqC3E72yqaSflTe-SJ7awKEQGSQl_8mxS0Tm1672jHEIE7UubMQ=w450-h975-s-no?authuser=0
NYKvds1sSWq1cdqGf7Ba0_Z4yRUvKGGg5cNasUOmNfjq7ofH7j-Yo7KpZw3w0Hl6n-8wKJ4nU2mvpVQv2D23hj_LNizJED12ZGwu4iYtrSFSsdGOEszC3HLNhOyJxslcFnLREuQgZ28UTLl2wS6yY-sYYpsL2rEBxLiv6hKbkKTpBlhXHwbr7ooawIY1VqB0vi31BeQ7Qg95W0krQ5qurZFIoYTvRX4OXpMFoF93lpcZd2Fp1HAGY4uoNqSJfjWKosT2LFnzLMR-2lE4joR4ECfXqYvAuVdz13oNKcTClGUf8O6kOwUGG2lnV3LFO88iejgCw9ipDjMw63EpCmif4DPOT2jZz6GB8xcCY3U5Rt2BDGqu1O_H4MctMeZXNoyFtV-9I-T5w11k_E3BsZaezmhS4M0DjR-er2wPDLHs8kr9QCvzDXZJHamdyyhBl5jyNbPqxJWJgCjdisccvbMVMlMrGQElopWC0DUOLf3R3JM95Ja0e3X1UbZvKkA0Vv8FohTKKsr_9QQ6_xu_rb2HmVMjbI3t-RUQWH0AzTW8qat2lXMr2E83wzj_fzIbYendIUAywEC4NbDewgVkKP3LDRK5e70RENCDEHEnCV2l7xY56e22yWsxIKO2Qts0Kwm4eK9zxWH-86bAxjBNlSMqxU9RS-u46PUthCXdrGyjHHB6c19m2StVfpOF1iv7S7khBzevTSIE8Pqma7iVYINt8rO1Cf7wWFcaR1krY_hsYRKHAyIxY9nwZ40sTLol4e8RdXgRrAinAA1Q7bCHeD25nOXSsiDKDwSNBh4voltu72f3kCKo6uiuW36vP8U7DHdo549BQa8WQdaOUwii6ubylh9GSlTxqMmkZUZjkxwQHcc1SdZi-3FI1za-yDbTrTdbQYJDeI7tqM9_UqaEmfjmbOdY8Zjua9-ZaMq2zPgVDwl3NgEQqA=w450-h975-s-no?authuser=0
dq7VSbCqwCK1_BYysVKMkhahb-uD0k4nAV-CAZlVqHwjYuWFdcI4GJsSy8QwPoWrFCpYGOm9Lh-SD2JxJ0u8uv-z0CErSgRJOHmcrRp4Pa-teJgH5WpzASKtxw601rZ11yru0hTGoWd8GKBXoQ5eM-Auw-53xOAixvZxKfPqKzMNRxL7rL284hTl4U8-0I2UCKAKRiTibWBVDBSXJyWHWhHyo9fffji0qOEJjO2f6UZy7k5GkuglzOnDBfNiblqrkazOuBAGhQ5e-6TkYmcofiLXgbU1HOOfactBAtGMjaH-J8Md8Ebql1HTRUCyacL4cU6APL0tqFb4JA_uP-fcdeq_meXd46mpm2i6rL5LLLof5jqayLv32-Gg2cVHzlD-9physVI8U8L8w4azV3eWGOKant--QebtWSObS_TcR9mZtlmOaD7mDfT5l33LE5qdbXTDRXfwY1BiD9x59pGc12bEVL_cXgtQ90Qy265soCjbuJ3OGIDBL9qFjUXIWQU8DdwfvlYdDZDWPxRtOv0u4lUDFCFP3ylWvuJFWOjDFp-NXHTf5b6kjkWPHDtsuLPztJDFRMJddk5kVkijdz1lmuF8nd5SMWrxI3wsXvgE2Ko8S8Zgrb7QugjM_0Ns_zxIwad751dfBusMHEICodHXtpcba1UdxDzWQyvb_7d6AqhijgnWikawSFeinD0SnnMufBThI63zFgmImuNfnhuj-6lNafz5Az4Dj-m71aPCyvZ07RKLgs1kbqmMDz0MmegG8gm1CWRHQzRAqjSdIxP_UyN9-mw0IA7iuZvjcW55cB-MieVlpRDV-QmD3_Kv-92Pt4eXlzckYwWLUX83dac5Nv782yJXFH3csTm4M7SZbomE55f7irYf1ZE69f1iYADqWJeYMs9f9AQ2VZokUu2dNpvuhFYtsxMN5VvOxFr3piTmGsjGkw=w450-h975-s-no?authuser=0
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
