rick mccarter Posted April 14, 2023 Posted April 14, 2023 I have a question my rear sliding window will open with the switch I can hear relay clicking when I go to close window I have nothing no clicking. I do have charging pad in center console. Can someone tell me were relays are located One relay thats clicking is somewhere down on right side of fuse panel I cant find it. all fuses are good also I have even replaced the switch still not working
rick mccarter Posted April 14, 2023 Author Posted April 14, 2023 27 minutes ago, rav3 said: Have you seen this video?
rick mccarter Posted April 14, 2023 Author Posted April 14, 2023 thanks for the video but I do not the charging pad on my console I have the pull down console
rav3 Posted April 14, 2023 Posted April 14, 2023 (edited) 1 hour ago, rick mccarter said: thanks for the video but I do not the charging pad on my console I have the pull down console Sorry but you said you had the charging pad in console on your 1st post. Are you aware that relay #51 is the Rear Slide window open and #52 is the close? These are in the Passenger side fuse box. Edited April 14, 2023 by rav3 1
rick mccarter Posted April 14, 2023 Author Posted April 14, 2023 ya I did sorry about that ya relays click when opening window but when you hit the switch to close nothing no clicks of any noise I also replaced the switch I checked the motor when jumped it turn both ways
rav3 Posted April 14, 2023 Posted April 14, 2023 53 minutes ago, rick mccarter said: ya I did sorry about that ya relays click when opening window but when you hit the switch to close nothing no clicks of any noise I also replaced the switch I checked the motor when jumped it turn both ways Replace #52 1
rick mccarter Posted April 14, 2023 Author Posted April 14, 2023 ya I did sorry about that ya relays click when opening window but when you hit the switch to close nothing no clicks of any noise I also replaced the switch I checked the motor when jumped it turn ok i ll try that
