Coming from the front right, I occasionally hear what feels and sounds like I'm going over a rumble strip along the edge or middle of a two-lane. It's at various speeds, and seems more likely to happen on slight curves. I'm thinking wheel bearing, but would welcome any other ideas. Thanks in advance for your thoughts!
That is most likely torque converter lockup starting to slip or fail during engagement.
It could also be a sign it is time to replace your transmission fluid especially if it is the older fluid before they made the change to the newer fluid.  The older fluid if I recall seems to absorb water and would cause the same symptoms. My 2018 I bought as a certified pre-owned had the older fluid. The dealer had never run it up to the transmissions operating temp and didn’t know it was having the problem. After I made them aware and raised a stink about it they had it flushed and the fluid replaced with the new fluid pretty quickly.  The problem went away. That was 2 years ago.
It is definitely worth a fluid change.  Caught early enough you can save it.  Just don't keep driving it that way.  If it comes back soon you can try an additive (Lube Guard 63010) to buy some more time.
That new fluid for the 8 speed transmission only. 6 speed takes the Dexron 6 fluid.
If the rumble is from the converter, I'm pretty sure it's too late for a fluid change to help. How many Miles on transmission
One year old transmission rebuild, stem to stern. I've had it back to that shop, who have a good reputation, and they deemed it fine. To me, the rumbling does not appear to be shift related.
It's frustrating because the noise only exhibits itself occasionally, and of course never with the mechanic in the truck! My guy is looking at the wheel bearings today, so maybe I will know more after that.
Thanks again!
Edited by ajs67donzi
My guy ruled out wheel bearings...goes to show what I know!
He "re-learned" the transfer case and front axle lock up, and we're both hoping that solves the issue.
I've only driven it twice since, without no noise recurring, so my fingers are crossed.
  • 8 months later...
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
