13 minutes ago, Chuck FB said:
The further they forge ahead and invent complexity the further we fall behind !.
So you had gone through the positive side of the braking system replacing wires and that for some reason made the trucks system happy, I was wondering what the condition of the negative side of the wiring system is in. Its been so long since I have looked at how they tend to wire up trailers to ground the axle hub I just don't know how elaborate or pathetic they create the negative path. Obviously your negative side is doing well enough to allow the brakes to function but why I asked how healthy it appears to be and if they run the negative from the hubs just to the frame and rely on grounding contact there and near the hitch the negative grounds there for the trailer plug ?.
My wiring had a blue and white from the main harness. I started there with both blue and white 10AWG to each brake.
Oh, so both power ( the blue ) and ground were completely changed out in this process which is ideal to get rid of any possible breaks in either the power or ground side. I wonder if there was any chance that in that whole mess of power/ground wiring that the power wire rubbed through into the ground wire and it created a dead short, not sure if that would blow a fuse or just make the truck throw a fit. Or simply a break in either the power or ground, if the ground side then it would try finding a ground through your trailer hitch !. Trailers and crappy chintzy wiring just seem to be a theme, often not protected properly from flying rocks or hanging mud or ice and it all goes to crap.
Yes I changed both.
The factory wires ran across inside each axle tube.
15 minutes ago, mjonesjr84 said:
Yes I changed both.
I'm sure nothing can go wrong there with the two wires entering/exiting a hole drilled into the axle tube, like no chance of it rubbing wires on the edge of the holes or being a stress point or that axle tubes will no doubt have a seam internally and if oriented at the bottom would have the wires bouncing onto that sharp seam ( unless they use seamless axle tubing ).
Kinda my thoughts as well. I ran the wires, which are encapsulated in a vinyl jacket, on top rear of the front axle tube secured with zip ties.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
