CARFAX Needed ASAP.. PLEASE...
It is a 2001 Tahoe. I have already looked it over and it looks and drives great.. I just want to make sure before I pick it up Friday..
1GNEC13TO1R162986
fyi, I am not positive the O is not a 0
Is the truck at a dealer? If so, ask if they can run it for you as a condition of the sale, and tell them you won't sign anything untill you see an un-edited copy. My dealer was MORE than willing to run a Carfax, had I not done it myself, I think he was even going to do it w/o asking me if I wanted it.
1GNEC13TO1R162986
I can run it for you at work on friday (work at a dealer) but dont have the password and stuff on me at home
ps its a zero. No O's in a vin #
Mike
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
