Racer593 Posted August 28, 2023 Posted August 28, 2023 I have a 2018 2500hd CCLB. It is mainly used for pulling my 11,000 lb toyhauler. The truck has 40,000 miles. I started noticing recently that on longer trips, the further into the trip I get, the acceleration from a full stop becomes almost dangerous. When I begin the trip, acceleration is normal, but After driving for a few hours, if I come to a full stop and accelerate (stop sign or red light) I can put the pedal all the way to the floor, and it barely comes off idle. Around 4-5 seconds later it will slowly start to pick up rpm and then it’s fine until I stop again. Engine and trans temps are all in spec and no SES lights on the cluster. Just trying to see if anyone else has experienced the same issue, and if so, what did you do to fix it.
newdude Posted August 28, 2023 Posted August 28, 2023 5 minutes ago, Racer593 said: Sorry. 6.0 gas. 6L80 6L90. How are the transmission temps? 6L80/90 are known for bad fluid pumps as a result of the torque converter failing. They won't always show codes either when they do.
Racer593 Posted August 28, 2023 Author Posted August 28, 2023 Trans temp was 185° at 90° air temp. Happened after about 4 hours driving.
GMCustomerService Posted September 19, 2023 Posted September 19, 2023 On 8/28/2023 at 1:39 PM, Racer593 said: I have a 2018 2500hd CCLB. It is mainly used for pulling my 11,000 lb toyhauler. The truck has 40,000 miles. I started noticing recently that on longer trips, the further into the trip I get, the acceleration from a full stop becomes almost dangerous. When I begin the trip, acceleration is normal, but After driving for a few hours, if I come to a full stop and accelerate (stop sign or red light) I can put the pedal all the way to the floor, and it barely comes off idle. Around 4-5 seconds later it will slowly start to pick up rpm and then it’s fine until I stop again. Engine and trans temps are all in spec and no SES lights on the cluster. Just trying to see if anyone else has experienced the same issue, and if so, what did you do to fix it. This is certainly not what we like to hear, Racer593. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2018 Chevrolet Silverado presenting weak acceleration. To do so, please send an email to [email protected] with ATTN: Racer593/GM Trucks in the subject line. Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement. Privacy Statement | General Motors Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com
Register a new accountSign in
