Took my 2023 Chevrolet Silverado into the dealer because my turn signals work intermittently than you shut off for 30 minutes and then they work after 3 trips to Team Chevrolet in Las Vegas they finally said they had to replace both head light assembly’s This does fix it but under warranty it cost Gm $3500 because one headlight is $1645 and the other one has a switch in it cost $1749 plus 4 hours labor. I really don’t see how this LED type lighting is an improvement over a $5 turn signal bulb . When these trucks are older and out of warranty you’ll have to take a loan out to fix a turn signal or total it lol
Just wait till one of the new headlights starts doing it again...we had one truck do it.  Replaced the right front headlamp, came back 2 weeks later same problem.
This is certainly not what we like to hear, Larry.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into your intermittent turn signal concern. To do so, please send an email to [email protected] with "ATTN: Lawrence king/GM Trucks" in the subject line. Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you.
To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
You might of got a bad one mine are still working perfectly knock on wood
  • 10 months later...
Chevy silverado 2023 10k miles. Exact same problem. Blinker stops working intermittently and resets after 30 mins. Haven't paid attention to how many trips it takes to do it but I will pay attention now. Ridiculous to have this problem this early.
Edited by Jbennett53
Misspelled
We regret to hear of this blinker concern with your Silverado and would like to take this opportunity to learn more and assist. To do so, please send us an email to [email protected]. Make sure to include your Username and Forum name in the subject line with additional details. We will look forward to hearing from you.
2 hours ago, ChaseMcAlister said:
Glad to see I’m not the only person experiencing this issue. Right front blinker stopped working tonight. Very frustrating with less than 36,000 miles.
What year and what model truck do you have?
  • 3 months later...
Imagine my consternation when I had my truck checked at 35,800 miles and there was no issue.  Now at 38,000 the blinker quits and the solution is $4,000 worth of headlights.  It would be a shame to have to trade in a truck I have only had for 4 months.
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
