Got some pics of my RPO codes, got a GU5 3.23 and G80. Fine. So is there a chart of axle models to RPOs? It rained last night, so I'm not crawling under my land yacht to get the tags or stamped codes just right now... Who made the axles?
My L20 4.8L runs sweet, but my WT has the tow package. Struggles to hit 20mpg, and that hurts when gas is $3.50+ a gallon. BIG fuel tank.
Had to get my plates renewed at local DMV... So I had to open up my Silverado anyways. Crawled under rear, could not see stamped numbers or tags. It is a ten bolt, for whatever good that does... No front axle, not really needed on a 2WD [CPT Obvious]
The axles were made by AAM (American Axle and Machine) and are Saginaw 8.6" or 9.5" on the 1500 GMT900s.
The G80 RPO code denotes that it is equipped with the locking limited slip carrier.
The ring and pinion ratios used in the 8.6" were:
GU4    3.08
GU5    3.23
GU6    3.42
GT4    3.73
GT5    4.10
The latter 3 ratios could be had in the 9.5" 15-Bolt semi-floater.  This axle was used behind the RWD and 4x4 pickups and SUVs with the L76 6.0 engine from 2007-2009 and the L92/L9H/L94 6.2 engines from 2007-2014.  An AWD Denali or Escalade will have the 8.6" axle out back.
A change in ratios might help city driving or highway mileage depending on which you select.  A numerically higher ratio will help with stop and go city driving, the lower numbers will help on the highway.  In my opinion in the case for the 4.8 with a 4-speed, you really don't want anything steeper than 3.73s.
Right now you're turning about 1,727 rpms without converter slippage on stock 265-70-17s.  3.42 would increase this to 1,826 rpms and 3.73s to 1,992 rpms.
It will likely takes years to recover the cost.  We pay more in fuel compared with new cars but for the most part, don't have a car payment anymore.
I was unable to contort myself to look on top of the axle for any codes. From looking at the stuff on the internet, I thought it would be an 8.5 , but I most certainly lack any experience in the axle and diff combinations.
2007-2013 1500s.
Unless its an NHT truck (max trailer) or a 6.2 or 6.0 Vortec Max, all of the other combos use the 8.625" axle.
NHT, Vortec Max and 6.2 use the 9.5" axle.
The 8.5" was beefed up sometime in the 1990s for truck use, they added an 1/8" to the ring gear and called it an 8.6".  Very similar 10-bolt housing as used in the 1980s, such as on the Buick Grand National.
Your RPO codes are in the glovebox.
Edited by swathdiver
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
