While under the land yacht, I noticed the bottom of both of my rear shocks were badly rusted, deep rust. They aren't leaking [yet], still work fine. Suspect they were originals, now I got @ 52 + K on the truck. I do have the Z82/Z85 tow package, so according to the ad droids, these have a 46mm piston and a monotube. I do want to have decent towing ability, but am not going to shell out for Bilsteins. The original tires might have cracking on the tread face, circumferential, follows between the treads. That will be fun. Rims are steel. God help me.
  I tow 1-2K semi-occasionally. Most of the time, the heaviest thing I haul is 400lbs of sand over the rear axle in Winter. No lift kit.
I want to run Monroe 911502 Reflex Monotube Shock Absorber Rear and 911501 Reflex Monotube Shock Absorber Front. I have no clue is the difference between the two is no boot on the front shock?
Any deeply buried painful memories with Reflexes on a 1500 Long Bed WT with the Z82/Z85 package?
  • Confused 1
You have front struts, so they will have to be disassembled to put in the new shock.  Might want to replace some of the worn out parts in the assembly while you are at it.
I would replace them with GM OE shocks, they will far outlive any of the aftermarket ones and are specifically tuned for your truck, not generic.
Tires are dry rotted and have reached the end of their service life.  They only last 4-5 years down here in the south unless garage kept.  The sun's UV rays do it.
Your shock codes are in your RPO sheet, the 6XX and 7XX codes are them.
 https://parts-catalog.acdelco.com/acesCat.php
Parts and Accessories search for shocks
6FZ COMPONENT FRT LH COMPUTER SEL SUSP (6FZ)
Part# 540-619 - ACDelco
Part# 20955498 - GM
7FY COMPONENT FRT RH COMPUTER SEL SUSP (7FY)
Part# 20955498 - GM
Eh, different RPOs, same P/Ns... GM is pretty proud of them, a C bill each.
'Tis true for the fronts, the rears are under the chassis code.
RPO code: Z85 CHASSIS PACKAGE,INCREASED CAPACITY
AC-DELCO says: CHAS PKG(Z85)
Oddly, there is nothing listed for Z85, 2 Door, Standard Cab Pickup. I did select "WT" as the trim level...
Edited by elric
Plug your VIN in at GMPartsGiant and have a look there.  They are usually the most accurate.
As for prices, you get what you pay for.  ACDelco OE and OE Rancho shocks are some of the best as far as endurance and ride quality goes.  They are tailored for your specific vehicle and not generic.
Edited by swathdiver
    btm
    btm
  • Who's Online   7 Members, 1 Anonymous, 1,317 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
