31 minutes ago, 64BAwagon said:
If it was cost cutting I would think Flint would have stopped as well since Flint builds more trucks than Oshawa. I agree though that GM has cheaped out on a lot of stuff. Rear diff drains plugs is one that comes to mind.
It’s not likely that the grit type material that makes up that texture is in some sort of short supply. Maybe the machine that applies it is down and someone just said meh, send um.
Entirely possible but we will never know for sure. As of today Flints still turning out trucks. Longer than i thought they could.
The big question is, is it really chip resistant or chip hiding? Answer: Gm doesn’t care.
11 hours ago, Tater86 said:
What's that odd's of those with Oshawa builds pushing back on their trucks to get them repainted the correct way?
I thought about it, I am indifferent about not having the rock guard. I figure it would be hard to add like how the factory does it, or it wouldn't be quite right added as an after thought. I feel like GM would not do anything about it anyway.
Theres  usually a disclaimer somewhere that says that the Manufacturer has the right to change anything on the vehicle at any time. Theres technically no "correct way"  You essentially get what you get.
On 10/3/2023 at 6:43 AM, GmEnjoyer said:
Does anyone with a 2024 have the rock guard / textured paint on the rocker panels like GM used to do? Did they stop for 2024 or is it on only certain trim or packages?
I have a '23 LTZ and mine does not have it. Coming out of my '19, I was surprised it was removed.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,448 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
