Mark l day Posted October 6, 2023 Posted October 6, 2023 I have a 2001 chevy silverado 1500 with the Ls 53 v8 and I have been getting a misfire code for the last 2 moth First, it started out as a multi cylinder misfire to cylinder 5 misfire. And I've changed Fuel injectors, spark plugs, and wires. After changing all that, it went from the cylinder 5 two cylinder 8 misfire And if I unplug my. Mass air flow sensor the cylinder 8 in the spirit goes away. And I also changed the coil to see if it would change. And it still misfire
asilverblazer Posted October 7, 2023 Posted October 7, 2023 One at a time swap plug, wire, coil, injector, plug wire from cylinder 1 to cylinder 8. One of those components will take the miss fire with it from 8 to 1, this is the component that needs replaced. Otherwise you are looking at a mechanical problem specific to cylinder 8. Non AC/Delco parts are suspect of being no good out of the box.
thx1138v2 Posted October 14, 2023 Posted October 14, 2023 Go to to your auto parts store and pick up a spray can of "Mass Air Flow sensor Cleaner" ($12.00) and clean the Mass Air Flow sensor by spraying the grid with it. Give it a couple of minutes to evaporate and put it back together and try it again.
Register a new accountSign in
