Would it be possible to add a steering column lock to a 2023 Silverado 1500 that wasn't built with it because of the chip shortage? What parts might be needed if it could be added? Thanks!
Anything is possible with the right amount of money, but I don't see a need to add it.
I was just wondering what parts might be needed to add it.
9 minutes ago, Tyler Davidson said:
Thanks! Where would I find the harness.
I am guessing that you would have to already have it as a part of your current harness.  Plugging something into the vehicle, when it has not idea what it is, is probably not a good idea.  If there is a plug in/around that area of the steering column, then you may be able to get it working.
Ok Thanks!
It can't be done.  There is no retrofit path for this.
The column lock module requires programming to the vehicle as would the BCM.  GM won't be able to flash these to add the option in, the truck is built as designed per the shortage.
If you really gotta have it, get a Club or trade in on a truck with the electric column lock.
I just looked at the steering column and it appears to have the module and it is plugged in.
8 minutes ago, Bikerjon said:
So you have the steering column lock after all?
Everything is there for it, but it says on the build sheet it doesn't have it
I don't think we are communicating here. Did you read or pay any attention to what newdude posted on here? Read it again and learn.
Didn't see his post. Makes sense though. Only reason I am asking about this is because my dealer said it is possible to retrofit.
...its not...
    EllDMc
    EllDMc
  • Who's Online   1 Member, 0 Anonymous, 655 Guests (See full list)
