Trying to replace the temperature control, blend door actuator in my 2005 GMC SIERRA 1500, but can NOT get to it by just removing the under panel on passengers side. It seems like I will need to remove the side panel of the center console, or the entire center console just to get to it- can anyone offer instructions, pictures, videos… step by step so I can get this done!??!! It’s TOO HOT to be without AC!
I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it?
80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉
By the way this is the "signature... ¬
Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least.
My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing.
Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit.
You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling.
Marv
Register a new accountSign in
