Yes. Mainly clips but there are screws under the passenger side end cover after you take it off.   Nothing complicated.  Dealer can print off parts diagram for you for reference.  What are you doing?  I vinyl wrapped my wood grain trim for a different look.
Hunting down a intermittent buzzing/rattling 😂
23 hours ago, forest said:
Ugghh ... break out the stethoscope
Thats funny, cause I just purchased one! It's random, so its hard to replicate. But i have noticed if i push up on the HVAC controls the noise stops.
On 11/18/2023 at 6:41 AM, Jus Cruisin said:
Sometimes all it takes is a few hits with the heel of your palm to "fix" and a rattle.
Haha have you had the same issue?
Nope. Not a squeak or rattle in mine but I can tell you techs will use that method to "fix" odd rattles. I have too. It sometimes only take that blow to rearrange wiring which is often the culprit.
Makes sense! Has to be wiring or a wiring clip since it’s not consistent!
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
