9 hours ago, TsRZR2 said:
And that is what I did as well. Put a cover on it and that helped a lot. But still, I am trying to get it across to GM, an $80K vehicle that when accidentally unlocked, will never lock itself back is beyond ridiculous. If I crank it with the FOB then do not get in and go within a certain amount of time,  it shuts down. Unlock it accidentally while downtown at midnight, it just remains unlocked. Too easy for GM to fix.
How is the truck supposed to know if the fob command to unlock is intentional or accidental?
It doesn't. That's why every vehicle out there BESIDES this truck has a "re-lock" feature. If you unlock the doors and don't -open- one within a certain amount of time, the doors then all automatically LOCK. While that isn't a way to "know" that the unlock was accidental, it's at least a way to make a reasonable guess that it was accidental.
If frequently unlock mine with the fob and want it to stay unlocked...
May or may not go to it and open a door in the next few minutes....
I'd be pissed if it 'relocked' when I didn't want it to.
SO has her GM vehicle (not a pickup) set to autolock and to 'honk' to confirm.
I keep mine set require active locking.  I use fob or by button on handle, depending on situation.
Edited by redwngr
I would be totally ok with an option to disable relock for folks like you that don't want it. I personally feel the complete lack of it is a bad design by GM, especially in a vehicle that ALSO has a poorly designed FOB that is easy to have the various buttons get pressed simply by being in your pocket.
I dislike the new fob design. It's hard to find out what to press without looking at it, in the 20' it's alot easier cause you can feel out where the buttons actually are. Plus the new fob the buttons aren't as satisifying to click. Lol
I just don't get why these things have to be so big.  My other fobs are at least 1/3 smaller and do the same thing with the same range.
On 12/2/2023 at 5:46 PM, TsRZR2 said:
This one seems to do the trick for the most part.
They do not correct the issue. After having this on the FOB for 36 hours, I have come out to an unlocked truck twice.
And OMG do they look awful from being in your pocket!
Yeah, I shouldn’t have made that FOB cover sound like THE answer. It is not. The answer is a smaller indented FOB and software that has auto lock back after a time of my choosing.
Sorry if it seemed like I was implying you over-stated. I only went back and grabbed your post because it had the details and was what I had on order to try.
I agree that the FOB is a bad design in many ways and also can't figure out why GM took away the re-lock option.
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 435 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
