I’m trying to find the correct part number to replace the 2500 HD emblems on the doors and the Silverado emblem on the tailgate. The Chevy site has numerous parts and the prices vary. Does anyone know the difference in these 2? They both look to include the door and tailgate emblems, but the prices are significantly different. What am I missing?
https://accessories.chevrolet.com/product/silverado-2500-hd-emblems-in-black-86539794?body=Crew Cab Pickup&bodyId=22&bodyNumDoors=5&bodyNumDoorsId=5&make=Chevrolet&makeId=47&model=Silverado 2500 HD&modelId=494&year=2024&bac=312157
https://accessories.chevrolet.com/product/silverado-2500-hd-lt-emblems-in-black-86539800?body=Crew Cab Pickup&bodyId=22&bodyNumDoors=5&bodyNumDoorsId=5&make=Chevrolet&makeId=47&model=Silverado 2500 HD&modelId=494&year=2024&bac=312157
Have you checked out Amazon or other online places? I bought a full set of black plastic emblems for my 1500 and got two Z71 badges plus the SILVERADO and RST badges for the tailgate for about $75. They are the proper size as well. I see emblems there that you could buy to make up a "complete set" for under $50 (I don't know if they're the right size).
From what you linked to, it actually looks like the more expensive set DOESN'T include the LT for the tailgate... the biggest difference you're likely to find with the aftermarket emblems is that they won't use the same adhesive to stick on. It's a thinner tape than what they come with from the factory. Worst case, you could replace it with something else if you needed to.
Yeah I noticed one of them included the LT badge as well, but with that one being cheaper it seemed really odd.
Thanks for the tips on looking elsewhere.
It might take you a little bit of searching to find a solid kit or combination of emblems, but a decent set should look good and save you a bit of money. The ones I bought for my truck look good and match the OEM size. I had to be fairly "purposeful" with the process I followed to install them, though. I taped everything off around the original emblems before I took them off so I had the positioning pretty much perfect and spent a LOT of time and effort getting all of the adhesive off from the factory emblems. I think I spent 3-4 hours in total on my truck with the majority of that time being spent on the Z71 badges on the fenders due to how much adhesive is used on them from the factory.
Hope your search and install efforts turn out well!
Dark Essentials is made up of 3 different part packages.
- Black Bowtie(s)
- Black "CHEVROLET" Tailgate Lettering
- Black door and tailgate emblems (1500,2500,3500 and then trim level)
For 2500HD Door/Tailgate:
WT and High Country use kit 84806915.
Custom use 84806909.
LT use 84912382.
LTZ use 84402407
Those kits contain the front door "2500HD" emblems, the tailgate "SILVERADO" emblem and on Custom, LT and LTZ the trim level.  Some of the badges are sold separately so you wouldn't need to buy the whole kit unless you needed the whole kit to change all the badges.
The "SILVERADO" badge for the tailgate on its own is 85631647.
WT does not have a trim level emblem, and High Country uses a "High Country" emblem in black that is sold as a pack of 3 so the two for the front fenders and then the tailgate one.
Edited by newdude
These kits including the trim level show $90, but the kit that would be used for a work truck (no trim level) is $220. See my links from original post. That’s what makes this so confusing. Why would the part with fewer emblems be more than twice the cost?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
